BOX1
P500 Accessory harness splitter
DK54
DK54
11
12
North Texas
Has anyone seen an [HASHTAG]#accessory[/HASHTAG] harness splitter. I bought some speakers to hook up to my P500 but it will plug directly into the accessory harness which will take up all the accessories I can hook up to it. The winch also needs to be plugged into the accessory harness so I don't know what to do to have them both plugged into the same accessory [HASHTAG]#plug[/HASHTAG]. Maybe your not supposed to so you don't overload the 12v harness but idk.
Moose308
386
289
Has anyone seen an accessory harness splitter. I bought some speakers to hook up to my P500 but it will plug directly into the accessory harness which will take up all the accessories I can hook up to it. The winch also needs to be plugged into the accessory harness so I don't know what to do to have them both plugged into the same accessory plug. Maybe your not supposed to so you don't overload the 12v harness but idk.
Only one I have seen plugs into the red female adapter and gas 5 different color leads.It might be 4?For running accessories and some are starter key operated. Oem from honda.
jak9922
jak9922
hot headed wopolock
3,277
5,589
pittstown ny
Very easy to splice into the factory harness and run whatever you what let me know what you are looking to do and ill do what i can to walk you through it
DK54
DK54
11
12
North Texas
Thanks for the offer but I had a guy from the dealership splice the cable in to the white wire of the accessory harness for the speakers when he was tying in the winch. Which was the only thing I didn't know how to do on my own for the winch install and the speaker install. I attached a pic of where I put it and what it looks like. Also I got the speakers off of Groupon for a pretty good deal in case anyone is interested here is the link!
Ancient Honda fanboi / RMAX traitor
243,703
I searched every possible way using the part number, etc. there does not appear to be any pictures of the sub harness on the internet. Even Honda doesn't have it posted up. I figured surely one of the vendors on Amazon / eBay / etc. would have a pic but I sure didn't find any. I wonder why all the mystery there are pictures of nearly every other accessory out there.
BOX2
box3
