One rear door is sagging a little and won’t latch when you close easy. You have to pick it up slightly. Now I have tried to lower the striker in the jamb, and it was as low as I could get it. I also tried to adjust the latch on the door and didn’t seem to help. The hinges on a normal door is where I could make this up but I don’t see any way to adjust the hinges. Anyone had any luck adjusting so the rear doors latch properly?
