P700m4 adjusting toe after lift kit
HondaVT
HondaVT
16
10
Going to put a strong made lift kit on this weekend and was wondering if anyone has had to adjust the toe on their machines and if so what is the best way to get it correct.
I did not.
61d55bba63f3e2fc6d9591fb77fc1922
Lynn
Lynn
263
134
Yakima,WA
I think it's a good idea to check it. Simple and accurate way is to jack up the front so you spin the wheels and scribe the tires with a long handled screw driver or some tool like that. You can Use a jack stand to rest your tool on and hold it steady. Then put it back on the floor and bounce it and roll it bath and forth a little to get all the tension out of the suspension, then just measure to your marked line front and back. Be sure the wheels are straight ahead.
Reactions: HondaVT
