P500 Air filter maintenance
5,015
22,380
Does tacobob oil that ink filter or is it dry ?
The intent of foam filters is for them to be oiled, that's what makes them so effective.
My point - if you're going to use a foam filter, oil it, it's how they work.
This was the tag included with my Uni pod filter.
I qS2Ch8v M
On my Talon -
I gXGK7GX M
At 1066 miles -
I KRxxBDV L
The stock filter at 1137 miles, their reputation is to need replacement at 200-300 miles.
I 2fqCwcL M
Idahocrawler
Idahocrawler
47
72
On my Talon -
At 1066 miles -
No you didn’t read what he uses the uni filter for .
he uses it as a pre filter under the oem cap . I want to know he oils that too
pretty simple question
5,015
22,380
Regardless of its location, filter foam works much more effectively when it's oiled - whether being used as the primary filter or pre-filter.
Pretty simple answer.
