P500 Air filter maintenance
rocmar
rocmar
4,741
5,776
4 CORNERS
Too much oil causes restriction. All we use in the shop I work at is K&N filter cleaner and / or Dawn, then after it's dry we spray the outside with PJ aerosol foam filter oil and work it in a little bit.
Not excessive..air restriction..not an issue
...machine not sluggish..or un responsive
But I know....wat your sayin
rocmar
rocmar
4,741
5,776
4 CORNERS
Yeah..everybody..likes there certain brand name
...it's a pretty basic maintenance. ..
ehart814
ehart814
1,690
3,821
NWPA
I'm going to snorkel for dust like @Little_g said. I'm going to put K&N prechargers on the snorkel ends or... I'm going to check out the filter skins and maybe use those.
I built my snorkel and found an outerwear that fits the end of a 2" ell. Got directly from outerwears website. I posted the part number before somewhere.
53f37a5ee0d88460bacd1850b1923346
ehart814
ehart814
1,690
3,821
NWPA
I have probably changed / cleaned my air filter a dozen times. I have 2 spares now. I used to use the UNI brand foam filter cleaner and oil. I decided to try the Maxima brand recently and I feel it's much better. And it's cheaper. They have a kit that includes both cleaner and oil at Rocky Mountain for about $15. Use the cleaner and then rinse it good. Then get a bucket and put dawn dish soap and water in it and clean the filter in that. Then rinse again and let dry. This system gets the filter really clean!
rocmar
rocmar
4,741
5,776
4 CORNERS
I just use Dawn...dish soap...
rocmar
rocmar
4,741
5,776
4 CORNERS
Doing air filter....today
....actually K&N... on the can directions..
states..to cover all areas...till red in color...
so that's alot of oil.. to turn a yellow
filter.....red.....
Just sayin....
Reactions: Dp5hunter
Deleted member 3748
filter.....red.....
Just sayin....
It's not that much on a white k&n filter though. I just switched to the spray k&n oil and it's great... For k&n filters. Not sure it would be great on a foam filter.
rocmar
rocmar
4,741
5,776
4 CORNERS
Direction state...spray foam filter..
been using it...for yrs..on all my
stuff....
Spray until you get a uniform red color
...they recommend..a K&N filter...
to me...red spray air filter oil....
can be used..on any wet oil filter
rocmar
rocmar
4,741
5,776
4 CORNERS
All spray oil...is pretty much...the same.. for air filters Goggled it...
so...it's a preferance..got 3 different brands..all
red...all the same consistency. .
rocmar
rocmar
4,741
5,776
4 CORNERS
Dude.check out my thread..of capsule
of green wires...share your knowledge / thoughts
...thanks
