Ran across this video and wondered how many people have done this upgrade and if it is believed to be necessary. It seems easy and cheap, so I have no problem doing it if it is worth it. Thanks for your opinions!
Definitely need it on a '16 model. It was either the '17 or '18 model that Honda corrected this problem from the factory after engine failures were reported. (they won't warranty engine failure even though it's their fault and they know it's a poor design). So...be on the safe side and get 'er done.Ran across this video and wondered how many people have done this upgrade and if it is believed to be necessary. It seems easy and cheap, so I have no problem doing it if it is worth it. Thanks for your opinions!
Definitely need it on a '16 model. It was either the '17 or '18 model that Honda corrected this problem from the factory after engine failures were reported. (they won't warranty it even though it's their fault and they know it's a poor design). So...be on the safe side and get 'er done.
Where did you source the parts?
This upgrade / improvement is an absolute must. Takes fifteen minutes $30 in parts to ensure you won’t kill your engine when you are out in the boondocks. We don’t do any muddling but we do Ford some small streams.Ran across this video and wondered how many people have done this upgrade and if it is believed to be necessary. It seems easy and cheap, so I have no problem doing it if it is worth it. Thanks for your opinions!
This is a GREAT suggestion and one I forgot about. My clamps were loose on mine and went around and tightened them up.It would also be a good idea to check all the clamps holding the intake tube together going to the air box I have saw where some people have found the clamps loose that could also let water in so make sure all the clamps are tight going from the front air box to the rear air box
Will these air intake parts fit the 2016 Honda p-1000-5 ?
Thanks do you know if these parts will fit the 2016 Honda p-1000-5?
