P1000 Air Intake Cover Upgrade Necessary?
PAoutdoor
PAoutdoor
45
82
Cogan Station
Ran across this video and wondered how many people have done this upgrade and if it is believed to be necessary. It seems easy and cheap, so I have no problem doing it if it is worth it. Thanks for your opinions!
0
0860silverado
945
1,813
louisiana
Definitely need it on a '16 model. It was either the '17 or '18 model that Honda corrected this problem from the factory after engine failures were reported. (they won't warranty engine failure even though it's their fault and they know it's a poor design). So...be on the safe side and get 'er done.
PAoutdoor
PAoutdoor
45
82
Cogan Station
Definitely need it on a '16 model. It was either the '17 or '18 model that Honda corrected this problem from the factory after engine failures were reported. (they won't warranty it even though it's their fault and they know it's a poor design). So...be on the safe side and get 'er done.
Sounds good. I am going to go to my local dealership and pick up the parts to do it.
Leonandlisa
Leonandlisa
39
99
Las Vegas
Where did you source the parts?
Reactions: Isaiah
Hondoman
Hondoman
727
1,695
Texas
My 17 had the old style. Ordered the parts thru a dealer cheap enough.
Reactions: Isaiah
TCM-551
Prescott
This upgrade / improvement is an absolute must. Takes fifteen minutes $30 in parts to ensure you won’t kill your engine when you are out in the boondocks. We don’t do any muddling but we do Ford some small streams.
PAoutdoor
PAoutdoor
45
82
Cogan Station
I just did it minutes ago. Only about $20 from my dealer and was very easy.
Reactions: Isaiah and Tuco69
tbaker
356
597
NW. Georgia
It would also be a good idea to check all the clamps holding the intake tube together going to the air box I have saw where some people have found the clamps loose that could also let water in so make sure all the clamps are tight going from the front air box to the rear air box
Little_g
Little_g
404
660
Parker, AZ
This is a GREAT suggestion and one I forgot about. My clamps were loose on mine and went around and tightened them up.
PAoutdoor
PAoutdoor
45
82
Cogan Station
Anyone have the part number for this off hand?
3F000E88 6149 4484 ADF7 AED03A4F74D3
Reactions: Isaiah
