Air intake temperature sensor
Shotgun34
0
Does anyone know where the intake temperature sensor is located on a talon r
5,032
22,501
Backside of the airbox, between it and the seatback.
Is it mounted IN the airbox or protruding into the airbox or is it just sampling temps between the seatback and airbox (not actually air in the airbox)? Inquiring minds want to know. :)
Izzat it, top center?
I pzZqzZr L
That is it, the way to access the plug is from the backside of the airbox.
Reactions: CID
What sort of chip?
You can reach it from below.
Might be easier to pull the whole sensor out of the airbox and unplug it then.
