P500 Air Pressure, Stock Tire
futzin
futzin
4,172
30,955
Kentucky
I know there's a sticky for this, but pretty much no one answered regarding the stock tire.
So: 'bump'!
My usage for the next couple of months is mainly field use, with light, easy trail mixed in.
Otherwise it's the usual Kentucky mix of gravel, dirt, rock, pavement and mud (I avoid mud when possible).
208,726
So: 'bump'!
Stocker, 15 PSI minium!
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,118
21,313
Route 66 Oklahoma
Hmm, 10 psi is recommended. What's your reasoning?
Yes it is recommended. Unless I am doing some agressive driving, I run 9 PSI front and 8 PSI rear for a little softer ride.
futzin
futzin
4,172
30,955
Kentucky
Thanks, SILVER_ALERT. My query was directed at Smitty335. Seems like an odd response. Perhaps he considers my question odd!
lee
lee
Village Idiot
2,387
13,520
Springfield Ohio
Tire pressure is dependant on terrain.
Soft or muddy = low, maybe approaching 1/2 the recommended pressure.
If you go too low you will debead a tire.
But somtimes it's better to drive gently with low pressure than to be stuck.
Hard pack dirt, small rocks = medium pressure, maybe 7~8 psi.
A little bit softer pressure than recomended will improve the ride a little but you still have half decent handling.
Too soft and the tires push too much when turning or you might hit a rock and pinch a tire.
Rocks, steps and big roots or a heavy load = pressure listed on the tire placard.
The possibility of pinching a tire is increased so run more air to prevent that.
The ride harshness is bad but that is better than walking.
Reactions: JCart and futzin
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
I'd experiment... I've ran as low as 4 PSI in the Winter and to 6-8 PSI summer,right now I'm running 10 PSI and run on the same terrain that you speak of.but i find it more bumpy rough,but rolling resistance is better...Lower air more contact patch.
Think I'm going back to 8 PSI...lol
This is all on stock Honda 25-10-12 Rubicon wheels and tires, 4 Ply..
Knock on wood there still holding up the abuse i give them.
Reactions: futzin
ckeele223
25
St. George, Utah
I have learned to respect the factory engineers and the incredible amount of research and development that is done, if Honda tells me to run 10 psi front and 12 psi rear in my Pioneer 700-4 that is pretty close to a baseline I can live with all around, I am still not shy about lowering those pressures slightly when riding exclusively in sand and then having the capability to raise those pressures back when encountering rocky terrain. I am amazed at how much these tire pressures fluctuate with the changing temperatures, much more than a car or motorcycle.
carlsonjmc
21
71
PA
So: 'bump'!
I drive at high speed and super aggressive in rocky, narrow hilly terrain (western PA to Hatfield and as far west as the Iron Range in MN. I run 15 - 16psi on 28” blackwaters on the 2016 Pioneer 5 and 14psi on the 2019 Talon X With stock tires and I still pinch sidewalls. My style is high speed cornering, too low of pressure and the machine has no side bite and corners slow as hell like your on Ice. It all depends on your driving style, if your into slow play with a plush ride with a chance at bashing a rim or popping the bead then run low pressure.
