PioneerPete
If anyone is still looking for the crank case ventilator, according to the service manual, it comes out of the valve cover and goes into the intake filter box so it should be good unless you get water down your snorkel.
I thought about making a post with this info and pictures. The only one I am not sure about is the crank case as you mentioned.
- fuel tank (most important)
- sub transmission
- front diff
- rear diff
- fan
- coolant overflow (maybe)
- What else???
I know there is a vent on top of the head with a built in check valve to disallow oil from exiting. There should be one on the bottom 1/2 Of the case also.
This needs to be explored!
Do you happen to have a parts list? (IE. Tubing size, tees, clamps anything?) Thanks for the help. I have the maiden off-road voyage this weekend and want to get to get it right before I get out. The winch should be here tomorrow as well, so I have a long couple of evenings after the kids soccer practice. I am hoping to stop by store tomorrow and get vent material.
To make life easier, auto parts stores sell an assortment of fittings all in one package. They are white plastic vacuum line fittings. Mine was less than 8 bucks. Would save you from looking for all those different sizes.Buy 25'+ of 1/4" fuel line. You will need a 1/4x1/4 barb fitting (ea) for the fuel line vent and the sub-trans vent lines. I used 1/8x1/4 barb fittings for the front and rear diffs. You could use a 1/4x1/4x1/4 barb fitting to then tie the fan vent line into the front diff vent line. Lastly, you would need another 1/4x1/4x1/8 (or 1/4 x 1/4 x 1/4 spliced into your new line) barb fitting to tie the adjustment box vent into the sub-trans vent line. The list would look like:
(25'+) 1/4" fuel line
(2) 1/4 x 1/4 barb fittings [fuel line and sub-trans under seat]
(2) 1/4 x 1/8 barb fittings (or a way to reduce from 1/4" to 1/8") [Front and rear diffs]
(2) 1/4 x 1/4 x 1/8 barb t-fittings [Fan vent to front diff line & adjuster box vent to sub-trans vent line] if you use 1/4 x 1/4 x 1/4 barb t-fittings, add (2) more 1/4 x 1/8 barb fittings to make the necessary connections
(14) 1/4" (or whatever size fits your new fuel line) stainless steel hose clamps
(25+) UV resistant zip ties
Hope this helps.
Thanks...Reconsider using the bellows....I forget who, but someone had seal issues after running the bellows. Run vent lines up to the roofline.
Bringing this back from the dead. Where are you guys actually running these vents to? I saw someone said roof line so are you running them up the roll bar? Just brain storming that probably doesn't look very appealing to the eyes
- sub transmission
- front diff
- rear diff
- fan
- What else???
Fan and 4wd selector box
Fan is the clear line on the fan. Selector box is under rear driver's side floor boardWhere are these at? I didn't see pics in this thread.
