P1000 all the vent hoses and locations
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I did the same thing this evening. I had an extra bellow so I put that on there.
E4cdbd0ca39819b439e711ddb209c93c
I think this box contains the adjustments for cable operated shifters. Not completely sure on this but seems like I saw a picture of it somewhere.
it contains the adjustment for the parking brake.
Reactions: joeymt33
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
If anyone is still looking for the crank case ventilator, according to the service manual, it comes out of the valve cover and goes into the intake filter box so it should be good unless you get water down your snorkel.
ofrcboy
ofrcboy
501
572
Oregon
Sorry but can someone post a picture of the fan vent? I am not sure where to look.
Johnny_C
Johnny_C
303
143
Western N. Carolina
This means that any volatile gasses are
recycled through the engine. That makes
me feel better about adding the bellows
pretty much everywhere else.
John
K
KD_Pioneer1k5
10
0
Wv
I thought about making a post with this info and pictures. The only one I am not sure about is the crank case as you mentioned.
- fuel tank (most important)
- sub transmission
- front diff
- rear diff
- fan
- coolant overflow (maybe)
- What else???
I know there is a vent on top of the head with a built in check valve to disallow oil from exiting. There should be one on the bottom 1/2 Of the case also.
This needs to be explored!
Do you happen to have a parts list? (IE. Tubing size, tees, clamps anything?) Thanks for the help. I have the maiden off-road voyage this weekend and want to get to get it right before I get out. The winch should be here tomorrow as well, so I have a long couple of evenings after the kids soccer practice. I am hoping to stop by store tomorrow and get vent material.
Hucker
67
138
SE AZ
Buy 25'+ of 1/4" fuel line. You will need a 1/4x1/4 barb fitting (ea) for the fuel line vent and the sub-trans vent lines. I used 1/8x1/4 barb fittings for the front and rear diffs. You could use a 1/4x1/4x1/4 barb fitting to then tie the fan vent line into the front diff vent line. Lastly, you would need another 1/4x1/4x1/8 (or 1/4 x 1/4 x 1/4 spliced into your new line) barb fitting to tie the adjustment box vent into the sub-trans vent line. The list would look like:
(25'+) 1/4" fuel line
(2) 1/4 x 1/4 barb fittings [fuel line and sub-trans under seat]
(2) 1/4 x 1/8 barb fittings (or a way to reduce from 1/4" to 1/8") [Front and rear diffs]
(2) 1/4 x 1/4 x 1/8 barb t-fittings [Fan vent to front diff line & adjuster box vent to sub-trans vent line] if you use 1/4 x 1/4 x 1/4 barb t-fittings, add (2) more 1/4 x 1/8 barb fittings to make the necessary connections
(14) 1/4" (or whatever size fits your new fuel line) stainless steel hose clamps
(25+) UV resistant zip ties
Hope this helps.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Hope this helps.
To make life easier, auto parts stores sell an assortment of fittings all in one package. They are white plastic vacuum line fittings. Mine was less than 8 bucks. Would save you from looking for all those different sizes.
K
KD_Pioneer1k5
10
0
Wv
Thanks Delton and Hucker, I'm headed to Napa right now.
boatman22
172
309
Woodlands TX
  3. Other Brand
Anyone have the bellows part# and where to buy?
Hucker
67
138
SE AZ
Reconsider using the bellows....I forget who, but someone had seal issues after running the bellows. Run vent lines up to the roofline.
Reactions: sharp
boatman22
172
309
Woodlands TX
  3. Other Brand
Thanks...
Tbowman053
Tbowman053
Henderson, MD
Bringing this back from the dead. Where are you guys actually running these vents to? I saw someone said roof line so are you running them up the roll bar? Just brain storming that probably doesn't look very appealing to the eyes
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Here's where I ran mine that go to the rear diff, fuel tank and sub trans. They are actually tucked a little further behind the roll bar than what this shows.
20160709 213202
Reactions: nbomar and sharp
39,079
Yep, that was me. The bellows lasted around 800 miles and I had them installed everywhere. It was the rear diff that blew a pinion seal while riding fast on a 95° day. It just couldn't expand enough. Also, the muffler is 1" from the rear diff so it gets heat from the exhaust.
nbomar
nbomar
4,416
17,854
Springdale, AR
- sub transmission
- front diff
- rear diff
- fan
- What else???
I got the sub trans, rear diff, fuel tank, leaving the front diff alone as others have suggested. What else am I missing.
Thanks guys.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Where are these at? I didn't see pics in this thread.
Fan is the clear line on the fan. Selector box is under rear driver's side floor board
Reactions: joeymt33
boatman22
172
309
Woodlands TX
  3. Other Brand
Has the how-to every done for the vent lines?
