All things R/C
211,916
Yes I thought it was speed control, It still hangs up some with 100% TH rate though and the steering is very weak in a jam, I 'm going to get the servo you recommended. Been watching all these You Tube vid's, about 95% are want to be analyst or camoed advertisements. I do appreciate all your help. I've got my controller set at TH-N, ST-R, TH Rate-50%. After messing with it the steering rate has to be at 100% to get full power to the servo?
And no it wasn't a flop, crawled right out of it some how! HA! Wood piles are challenging for me. Loving the 2.2's.
IMG 4968
62,510
Alright, here we go..... start to finish on the Gatekeeper body
Design drawn, body liquid masked, and everything cut:
1612471571957
1612471589478
Silver goes down first since you back it in black. You back most of your metallic colors in black so they "reflect" better. White tones them down a little if you don't want it to stand out as much.
1612471676931
1612471688832
Silver sprayed, now peeling off all the areas that are going to be black
1612471706053
1612471752955
Black sprayed and now onto the red "straps" and seats for the interior
1612471820451
1612471833165
I pulled the overspray film off before I was finished so I could make sure I didn't miss any little pieces of liquid mask. I cut all the buckles, steering wheel, straps, and I made some "straps" for the gloves 😁 . Lots of little pieces of mask to weed out:
1612471975438
Pulled the white area out of the roof for paint
1612472036986
Now onto the fluorescent green and yellow. This is actually a transparent standard green, but when backed with a fluorescent yellow it gives a really nice transition/fade:
1612472119045
You can see where I accidentally bumped the black painted area when peeling the liquid mask off and had to fix it. Just a little dab of black on a q-tip fixes it right up. Always good to double check by holding up to a light before spraying a light color after the darks are laid down so you can catch things like this. Otherwise you end up with a big white splotch in your black:
1612472132523
1612472144348
1612472154999
After the green and flo yellow are laid down, I pull out the other more technical areas that will be white. All of this gets backed in white
1612472257976
1612472272648
After the white is laid down. The roof/hood are done at this point so I pulled the film off:
1612472502542
1612472538604
1612472554663
1612472569991
Only thing left is to do the red drop shadows and the flo orange. Transparent red for the drop shadows backed with fluorescent orange
1612472637409
1612472650587
You can see it starting to take shape now...
1612472678721
Backed with white:
1612472711666
Film pulled off
1612472786603
You can see the red drop shadows here and how well the transparent red blends with the flo orange:
1612472827408
Everything all finished up, just need to get it cut out and on the buggy!
1612472874722
JenElio
JenElio
82,203
714,325
Loxahatchee, florida
Backed with white:
Film pulled off
Thats Baadddassss!!
Todd627
Todd627
57,265
624,731
MI
Backed with white:
Film pulled off
Wow!!!! That is amazing Adam!!!
Fatsquatch
Fatsquatch
Approved Member
121,169
1,010,368
Hidden
Backed with white:
Film pulled off
Artist at work
Coeus
Coeus
Major General
75,662
688,949
Signal Mountain, TN
  2. Talon R4 LV
Backed with white:
Film pulled off
I’m still 🤯🤯 about figuring out the right layering
211,916
Backed with white:
Film pulled off
Dang looks great Looks like a bunch of work. Thanks for the tutorial!
211,916
Oh and I guess I need to put the heads on the driver and passenger, lol. s*** I need to find them now or steal the ones off the other interior.
HA! Who needs heads? I'm still looking for a stock clear Night Crawler body w/o bed and drivers? Well scratch the bed, it's part of the main body' still like the Zebra stripe thing and naming it Smitty's Safari Wagon!
Mopower58
Mopower58
Unburdened by what has been!
87,659
752,002
Crystal Springs,Ms.
Backed with white:
Film pulled off
Great work!
62,510
Everything was going too well... Lol. I guess this black paint didn't like the clear coat. Sucks but at least it's on an interior piece. Usually you get this if the temps aren't right or you don't shake the can enough, but that wasn't the case here. Sprayed all my panels and the interior of the kids body with no issue. As soon as the clear hit the black it spider webbed like crazy. Now I know to back all the black from this particular paint with another color before clearing it
PXL 20210205 022937934
PXL 20210205 022945349
PXL 20210205 023023200
