Amazon oil
Vikes79
Vikes79
SKOL!
11,773
114,152
South Dakota
  2. Talon X4 LV
Most likely packed by Warren Products. Most house brand oils are done by them (Walmart, etc).
I wouldn’t think twice about using it.
69,244
Project farm tested it. Believe it scored well.
Reactions: JTW
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
it is a warren product. ill pass. ill keep my honda oil and rotella.
Vikes79
Vikes79
SKOL!
11,773
114,152
South Dakota
  2. Talon X4 LV
I’ve seen nothing but good used oil analysis on Warren oils when the mfgers interval was used.
Just like anything else they have a time and place. I certainly wouldn’t go past the recommended interval.
Reactions: JTW
60,948
Do an analysis and let us know how it held up. It is cheap
I'll give it a go next time around in the Si. I've used Royal Purple in every vehicle I've owned since I was a teenager and never had any sort of issue related to oil. I drive 110 miles round trip every day for work so I end up changing a lot of oil, so I'll give it a whirl next oil change and see what comes of it.
dang thats a long commute every day
They can’t lie on the oil rating so if it is rated SN or SN plus that means it is a very good oil.
But you could still run it twice and do an oil analysis on the second time and see how it does. Of course you’ll need a baseline on the current oil you are using before you switch
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Yep, but working in New Orleans pays double what I could make doing the same job closer to home. I get to work from home pretty regularly so it isn't an every day thing. Still sucks...
s*** i dont blame you. better to work there than live there.
Reactions: BigOL3
182,107
Been running RP forever as well. My current commute to this project is 91 miles each way and just came off of one that was 107 each way. Just have to keep an eye on the oil levels as RP is notorious for using a little.
Reactions: Remington
43,292
Come to think of it, I will probably run it in the wife's next time. We use supertech syn, and change it every 5000. She has a long commute, and it uses a bit of oil.
Reactions: trigger
