P1000 Another tire/wheel question
c_hurt
c_hurt
19
Oklahoma
Is anyone running wider tires in the back with the same width rim on all four corners? I bought some 29”x9” for the front and 29”x11” for the back, but bought 14”x7” rims on all 4 corners. Anyone have experience with this? Thanks.
JenElio
JenElio
65,087
609,145
Loxahatchee, florida
What machine?
JenElio
JenElio
65,087
609,145
Ok, the width won't be a problem on the rear. You'll just have a bit more sidewall bulge then the fronts. Do you have the forward arched arms though? 29" will most likely rub with out them, or a lift.
c_hurt
c_hurt
19
Oklahoma
That’s what I was hoping, however, I’ve heard that if the tires aren’t the same size ratio as the stock, then it can screw the rear end up when in four wheel drive because the wheels won’t be spinning at the same speed. The stock rear wheels are wider than the stock front causing the rear to kinda squish down and set shorter height wise than the front tires. Just don’t want to screw something up.
Reactions: Lady01 and JenElio
JenElio
JenElio
65,087
609,145
I don't think that sidewall flex will give you issues like that. My 2 cents, Just like having more/less psi front and rear. Unless you ride pavement A LOT and in 4wd then I don't see it being a problem.
Vikes79
Vikes79
SKOL!
10,996
106,744
South Dakota
  2. Talon X4 LV
Not quite true for our machines.
It’s the diameter that matters.
The stock tires are already narrower in the front than the rear by design even though most air all tires to the same value.
c_hurt
c_hurt
19
Oklahoma
That makes me feel a lot better about these wheels. They look great, just didn’t want it to cause more problems that it was worth. Thank you!
It’s going to be extremely close without a lift, but they might actually work after seeing them on the machine (fingers crossed). If not, I’ll put a small lift on it or look into the forward A-arms if I do get some rubbing. I appreciate the info man.
JenElio
JenElio
65,087
609,145
That's what we are here for brother!
And welcome to the club from South FL
They say......pics or it didn't happen!
#NTC
  • Haha
Reactions: Lady01 and Vikes79
c_hurt
c_hurt
19
Oklahoma
After putting the tires on the rims tonight, because the rear rims are narrower than stock, the rear tires are just a bit taller than the front. Which is still opposite from what the stock wheel were. (Front taller than the rear). This still should be fine to run?
Vikes79
Vikes79
SKOL!
10,996
106,744
South Dakota
  2. Talon X4 LV
I doubt it’s any different than factory unless the real diameters of the tires are grossly different. As long as the first two digits on the tire and the rim diameters are the same you should be fine regardless of the width.
Cjtwicks
Cjtwicks
Cottonwood California
I have a 2019 PK1-3 with stock tires and rims and I want too get new rims and tires and go up too a 14” rim instead of a 12” and the rims and tires I’m looking at are the M1 Evils tires, I was wondering because I was thinking of putting all the same size on all four so I can get more wear out of them? Any imput would be appreciated because when it comes to the sizing I’m lost! The set up I’m looking at are the rims on the right the fuel and the M1 Evils on the left? Which would you all think would be best? Thank you!!
D82D6A3F FDAA 4A9F 8115 3BD91C3C7C4B
C74B3F40 3CBB 4883 9BAB E484AAD0F617
Reactions: Lady01
c_hurt
c_hurt
19
Oklahoma
#NTC
Just so we know it happened! ITP 29” tires and 14” rims 9” wide on front and 11” wide on back. No rubbing whatsoever so far. Haven’t taken it out on the trails, but it handles sharp turns on the road without a problem. Just got it cleaned up today!
F7666454 465A 4888 927D 4B5F04D69527
TripleB
TripleB
11,935
101,313
Caryville, Tennessee
Just so we know it happened! ITP 29” tires and 14” rims 9” wide on front and 11” wide on back. No rubbing whatsoever so far. Haven’t taken it out on the trails, but it handles sharp turns on the road without a problem. Just got it cleaned up today!View attachment 249558
How tall are they with a measuring tape?
TripleB
TripleB
11,935
101,313
Looks good.
JenElio
JenElio
65,087
609,145
Looks good!
Is that a seat cover? Looks nice
