Parts needed:
Heater AH 200
aquahot 4 way valve
teflon tape
1/2" npt to 3/4" barb x 2
3/4" npt to 3/4" barb x 2
two 2 foot 90 degree at one end 3/4" hoses bought at autozone ( think they come longer)
Form Ebay: GOODYEAR HVAC HEATER HOSE, WIRE SHAPING COIL (P/N GY34BX) - three
hose clamps - buy 10 pack from autozone for 2.5$
1 gallon honda coolant
I used opening in the metal grill plate to route two hoses for heater next to inlet radiator hose. Was a bit complicated but rewarding and no new holes to drill . Here is pics. Just tired to write anything tonight. Was testing and it works. Time will show. Heat output very decent, better then none.
One small addition to the above, I had to make shorter heater holding bracket to make it compact and not to stick out so much into cabin, had about 1 cm (less the 1/2 inch) behind vent left to suck the air. and also create holding point , see drawing below.
Heater AH 200
aquahot 4 way valve
teflon tape
