P500 Battery life
Moose308
386
289
What is the expected battery life for sxs and atv?I keep them plugged in on battery tender jr.
ncred02
ncred02
1,031
1,769
Raleigh NC
funny you should mention. I just plugged mine into a tender not 5 minutes ago. Thats a great question. Mine has been going strong since May 2015. But I too wondered when I should change it. It would suck major if you shut off your ride to take in the sights and couldn't crank it back up.
I'm sure you cant push start a 500.
And is there an upgrade for the battery? Lately when I ride I don't shut it down until I'm back to the truck
Reactions: Ollie and Moose308
gullyjumper
gullyjumper
950
2,413
cookeville tn
They will last for years with using a trickle charger
Reactions: rocmar
rocmar
rocmar
4,741
5,773
4 CORNERS
Hot & cold...is wat ruins
your battery...you'll know
when it's ready to go...
the battery they come with
Probably concidered a
medium grade.....
trickle charge...or remove
in cold
158,264
I run a tender on all of my electric start small engines. I even run one on my truck, due to something drawing on the battery. I think it's one of the amplifiers.
This is one of the coolest things they can do with Lithium batteries now. I think I paid like $69 for this on ebay in early April. Threw in it the toolbox and checked it once a month, always showed full. Three times recently I let the truck go dead, and this little sucker jumped it all three times without putting a charge on it for close to six months. Put a fresh charge on it now and back in the toolbox. The days of jumper cables are done. Bestek in Hand Bestek in Case
ncred02
ncred02
1,031
1,769
Raleigh NC
This is one of the coolest things they can do with Lithium batteries now. I think I paid like $69 for this on ebay in early April. Threw in it the toolbox and checked it once a month, always showed full. Three times recently I let the truck go dead, and this little sucker jumped it all three times without putting a charge on it for close to six months. Put a fresh charge on it now and back in the toolbox. The days of jumper cables are done.View attachment 23857 View attachment 23856
Thats a must for out on the trails alone
I need to get a couple of those
34,174
Yep, that's the ticket buddy. I have similar with equal results.
34,174
Picked up my P5 late July 2014 and I'm still on the OEM battery with never a hesitation.
Reactions: SBuckJ and Moose308
Shadesmn
Shadesmn
505
959
Ramsey, MN
In my past experiences with my atvs as long as you are using them occasionally, they last for many years. Only time i had issues was when they sat unused for months at at time. Or in the cold for too long with little use. But trickle chargers never hurt. Thats what my bike gets over the winter months.
ehart814
ehart814
1,654
3,643
NWPA
As others have stated, freezing temps are hard on the little batteries.
One thing that will help your battery last longer: open up your battery box once in a while and clean the battery off - especially the top. Spray some degreaser on it and hose it off so it's nice and clean. If there is a lot of dirt/mud on the top of your battery, it will draw it down over time. Same for your cars/trucks. Keep the battery clean.
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
Trigger... Do you have a winch? Is it connected through the key switch (does the key have to be on to use it?)
They can draw several millivolts all the time holding the relay.
Reactions: JTW
158,264
Yeah, I have a KFI Stealth 3500 and the switch is wired into the harness, I think, but the leads go all the way back. Maybe the switch was just powered off the solenoid, can't remember.
Why, what do you mean?
34,174
Batteries are happiest at 72*, maintain that (lol) for maximum battery life.
Deleted member 3748
@trigger - Is this the battery pack you're using?
Amazon.com: BESTEK 600A Peak 10000mAh Car Battery Charger Jump Starter, Li-ion Battery Booster with Dual USB Charging Port and Built-in LED Flashlight, Green: Automotive
Reactions: trigger
158,264
