P1000 battery stinger question...
sheba4
161
197
mn.
  3. Big Red
Gary here in minnesota. i was told that in cold climets the stinger has failed on some units... is that true? should i just not install the stinger? i use my p1000-5 in the winter mostly for ice fishing... 10 degrees most times...
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Use a normal solenoid and a switch
OnTheJob
OnTheJob
426
925
Bristol, NY
I had one and it froze on a regualr basis on me. Replaced it with a Cole Hersee. Works perfectly now.
sheba4
161
197
mn.
  3. Big Red
Ok thanks, I guess I will.try one of those..
Where did you get yours?
Thanks,
Gary
TripleB
TripleB
11,722
99,602
Caryville, Tennessee
Reactions: Lapcinski
1101HotDog
Fargo
1101HotDog/Bill here in beautiful, sunny, tropical North Dakota. I built mine exclusively for ice fishing and I've had issues with my 2nd battery engaging accessories. My coldest starting temperature has been -27 F and the Pioneer has always started. After it's started, I'll flip the auxiliary battery switch to engage the accessories and there's been a delay of anywhere from 10 to 25 minutes before power is flowing thru the system. I had a real pro with wiring, help me build the project and we both agreed that the blockage has to be the Stinger. I brought along a voltmeter so I could identify this anomaly but apparently a watched pot doesn't boil. Ever since I started to carry the voltmeter, there hasn't been any issues. The Stinger Mfg say that it engages at 0.3 amps. Not that the Stinger has failed, but it sure seems to have electrical constipation at below F temps, but always works when it's a balmy 0+F temperature.
Reactions: TripleB
TripleB
TripleB
11,722
99,602
My stinger was doing the same thing in only 30 degree weather. I could tap on it with something and it would open up. It's only a year old. I replaced it this Saturday with this.
Dont know if it will be any better or not. It mounts directly in the holes that the stinger was mounted.
ehart814
ehart814
1,654
3,643
NWPA
My stinger was not working a couple times this winter when plowing snow. Wouldn't engage and let power through, so my winch wouldn't work to raise my plow. I tapped on it a bunch of times and it would start working. If I have any issues with it in warm weather, I'll replace it with something different.
Reactions: TripleB
1101HotDog
Fargo
Thank you, I ordered a Cole Hersee this morning. I've got a 4 day ice fishing trip coming up, so I'll be ready if there's any trouble.
Reactions: TripleB
