P1000 Bed Extender
Pirata
Pirata
31
152
2nd Star to the Right
  1. 1000 6 Crew
I was looking at some of the scrap around my workshop and found that the cage for an IBC 275 gallon tote is about the perfect width for the tailgate. I cut off the bottom and sides so that it would fit the tailgate. Once cut off I folded the open ends of the tubing then welded them closed. After this was all done I added a bracket to mount to the tailgate stay bolt so that it can flip back in when I don't need an extended bed.
Issue 1: I need a washer and longer bolts on the tailgate stay. When folding up or down the bed extender gets hung up in the tailgate stay cable so I will need to add a spacer when I add the longer bolts.
Issue 2: I need to add some expanded metal around the bed extender to keep contents of the bed from coming out.
This is still a work in progress but the basics are done. Attached are pics of this project.
20230820 123915 20230820 130510 20230820 130757 20230820 142622 20230820 151301 20230820 151429
Pirata
Pirata
31
152
  1. 1000 6 Crew
Before you guys start thinking how star spangled awesome I am I decided to rethink the entire project. The entire assembly bounces while driving. It binds and is cumbersome to install/remove. I may try making something out of sheet metal or expanded metal with a hinged tailgate. The tailgate I may use part of the IBC cage and the sheet metal for the sides. I'll keep you posted as I look into something better.
