Been in the shop over 30 days
K
kidamer
ohio
Brought in my 2020 talon for its second service, I advised the service guys its been making a popping sound in the rear end as well if they could look at it. Well they said the driver side rear axle was bad so they replaced it, after replacing it its still making the same sound, so now it seems they and Honda are going back and forth on what to fix. Its day 31 now and still in the shop, needless to say its very annoying at this point.
Has anyone had any luck on lemon law with side by sides or should I let them fix it and trade for something else, I would imagine the lawyer fees would probably be equal if not greater in the hit of value any suggestions?
Reactions: TimG
HondaTech
Have they tried the other side axle?
I've found its difficult to pinpoint which side it is sometimes and you've got a 50% chance at getting it right.
Most "popping" noises I've repaired have been axles. But it could also thr driveshaft U-joints as well.
Reactions: CID and 1HasBeen
1HasBeen
288
726
Wickenburg, AZ
I would sometimes walk behind the machine while our tech was doing, slow, tight figure-eights to try to pinpoint the source. It can be a bugger, but a month? Nope.
K
kidamer
ohio
yes they did replace both axles, now the fight with honda they said is to replace the rear diff, good grief set back of another week or two
K
kidamer
ohio
yeah it seems excessive to me as well
Jodyvaughn1963
10
Radford, VA
  1. Talon X4
I just purchased a 2021 i4x live valve a month ago I have noticed on 4 occasions loud clinking sound coming from the rear might be transmission, transfer case or differential. It is at the dealership for the first service, myself and the mechanic have tried to make it repeat the sound but have not been able to.
K
kidamer
ohio
Finally going to get mine back after over 30 days replaced both rear axles and the rear diff. Mechanic said the noise is gone. But mine only had 700 easy miles ride it around on the farm so, god only knows how many miles before it happens again
MDFMac
135
240
upstate ny
these things make noises. not all of them are things that are broken. matter of fact.. i have never owned a off road machine that makes as many noises as a talon. :)
Rednick69
Rednick69
154
1,260
White Hall, AR.
I would think it was a fluke thing and I wouldn't expect it to happen again. Outside of the BS time you had to wait, think positive muh dude.
Reactions: Josh97stang and CID
Killer223
Killer223
265
530
One of my loud popping noises was the coil separators contacting the crossover rings.
