Best method to tie SxS down on trailer.
182,437
Trailer with P5
5,492
25,271
Post #27 here -
What is everybody doing? I looking for most efficient and quickest way to make it happen.
E-track with bonnets. Only way to go…👍
Reactions: Remington
P1K5Dave
P1K5Dave
2,260
8,463
Petoskey, MI
I like the tire straps best as well. The main key is to take the suspension out of the equation as much as possible - if you were strapping to the a-arms, for example, you'd want to strap as far out on the a-arm as possible, close to the tire.
The worst thing you can do is to strap from the bumpers to the trailer. This allows your machine suspension to flex with the ride, which will almost certainly cause it to shift around as you go.
BigDeeeeeeee
BigDeeeeeeee
53
244
That's the kit I've been looking at. What do you mean about quickness?
It's not as quick as straight straps to a couple tie down points, I have a friend that hauls in an enclosed trailer with just 1 forward and 1 back strap, he can be closing the door before I have my stuff layed out. For me, without an enclosed trailer I stash my straps in the truck. So I get back, roll up on the trailer, get everything out , it takes a minute or two to get the nets over the tires, tighten them all up. It all takes a few.
Reactions: ChadD and CID
BigDeeeeeeee
BigDeeeeeeee
53
244
It does sway some, I can't imagine it's more than a couple inches, I guess it would depend how fast you take the corners.
tdhanses
tdhanses
1,044
3,553
Kansas
Very old pic! Machine has drastically charged since then lol.
Same as @trigger and i still use them to this day and I use them on the eTrac in the TH.
And the link…..
Erickson 09160 Wheel Chock Tie-Down Kit Amazon.com: Erickson 09160 Wheel Chock Tie-Down Kit : Automotive
Just be careful if you ever drive on wash board, I’ve found the front tires move and then the single over strap falls off. The wheel chocks have kept it in place but I've left with the straps as tight as i can get them and then stopped to have one or both straps off the front tires when on rough roads.
I have theses exact ones from Erickson.
I wish the Mac’s had an etrack version of theirs.
P1K5Dave
P1K5Dave
2,260
8,463
Petoskey, MI
That's why I'm planning on getting the ones that basket over the tire. Those single straps make me nervous.
I believe there are options to do so with etrac(?)
I don't even have a dedicated trailer yet, but I've been looking. I have 1500 miles worth of trails 4 miles from the garage.
tdhanses
tdhanses
1,044
3,553
Kansas
I’m really jealous!! That’s pretty dang cool!
Reactions: CID
115,818
Only happend one time for me. That was when i had one set just for the front that was 4 years ago. I now have 2 sets front and rear 4 straps (recommended) for that trailer. You have to and should ratchet as tight as u can ro keep them tight. My cabin has a stretch of road for 10 miles thats rough as Hemorrhoids and they never come off. Ive drivin 500 miles to RRB a few times and no issues. My TH has ETrac and i use the same straps in there and went to Colorado 1,200 mile trip and never came loose.. Sure u can use the basket ones, (expensive) but if you just use 4 of the single straps and make sure there good and tight your fine. 4 years this way and roughly over 70k miles with them. I think im good lol.
Reactions: Brmcg324
