TxDoc
I take care and don't abuse my machines. I have 28 inch tires, no lift, no spacers. Essentially stock.
My 2001 Rubicon and 2004 Rhino were sold in 2020. Rhino had original belt. Rubicon zero problems.
Just routine oil/filter changes and washes and were stock, just winched put, no wild/desperate red line wheel spinning.
Having read about people ruining their transmission in literally a few feet and seconds...
So, if you are going thru deep/sticky mud or pulling someone out, in Fri snow, going uphill, etc , what is the most advantageous thing to do?
Be in manual shift mode and stay in 1st gear?
Is in auto, use performance mode?
What do you do and what do you avoid because you've seen bad results and know not to do those things? What gives the machine the best advantage over the conditions?
Thanks
Thanks
