P1000 Bilge fan
Dordon
Dordon
41
128
Eastern Kentucky
I know this has been discussed before but what would be the best and quietest for eliminating heat 2 3" bilge fans or 4" bilge fan or a 8" radiator fan, I have seen everyone using different kinds also what brands are recommended. Thanks everyone for the input.
115,288
It's all a preference to you just make sure it moves enough CFM that is cubic feet per minute for those of you in Rio Linda.
I have a 4 inch bilge fan under my seat that's been there since 2016 pointed directly at the exhaust manifold and it has served me well. With the wife that is. As they say happy wife happy life
PJon
PJon
792
3,208
Arizona
Originally I installed a 4” bilge fan installed like the DEI kit that sucked hot air from under the seat and then blew said hot air out the through the skid plate through dryer vent tubing. Worked well, but started making noise then ultimately blew the fuse. Checked into problem and found bilge fan distorted from heat and the impeller was locked up. I removed the whole setup and installed an 8” spal fan blowing air back over the exhaust headers. Works great now.
StewB
StewB
720
3,340
Here's my recent post. The radiator fan is pointed across the exhaust headers and is quieter than a 3" bilge fan.
I do think it's a matter of preference.
As for the fan I used, google:
7" inch Black Slim Radiator Cooling fan 800 CFM Mount Kit
The 800 cfm is a lot more than the 3" bilge fans, but it isn't as directed as when using ducts.
Y
Yakman
127
314
WA
I rigged a bracket for my 3" bilge blower and angled it at the exhaust header. Flip the dash switch and seat instantly cools down.
20220625 123150
bumperm
bumperm
1,897
6,774
Gardnerville, NV
That'll work, no doubt, but it looks like you have the blower mounted so the intake is at least partially obstructed. Best if you can keep obstructions at least a fan diameter away from the end of the intake, more is better. The goal is to have laminar smooth flow (no turbulent air) hitting the fan blades. They will be more efficient, move more air, and be less noisy as well.
Air flow is a whole 'nuther science, and real world testing can show unexpected results. I tested my installation using a hand held anemometer to measure exhaust airspeed with the blower in free air. Installed it, first picture. Then thought I'd "improve" things by cutting off the intake size reducer. Originally I measures 35 mph at the exhaust side. After cutting off the intake "restriction", that was quite unexpectedly reduced to 30 mph. I screwed up. I did order another blower though, so I'll fix my screw up when I have time.
20211210 212543
I got a dumb idea, this should work better! NOT!
20211213 153122
208,725
I think from now on, I'm just going reply @JACKAL and let him finish my reply on posts like these. Thanks @JACKAL!
bumperm
bumperm
1,897
6,774
Gardnerville, NV
@Smitty335 . . . okay, now I'm confused (which in retrospect is not all that unusual I guess), but I went back and didn't see a post, comment, or anything else from @JACKAL in this thread. Are you connecting with him via some sort of medium or??
  • Haha
Reactions: Vikes79 and JenElio
271,866
Trying to decipher Smittyisms is an effort in futility. Not sure what the question is being poised, assume it's bilge fans? Anyway, my posts on all these issues go back to the years 2015-2016. Once I dealt with it 6 years ago, I tend to not regurgitate the subject unless asked. I'm not the Pioneer or expert just one of the first handful here to do it and document with pictures.
271,866
The general consensus is the heighest cfm of "directed" air flow blowing onto the engine headers and flows beck and out the passenger side, say 15-20 degree angle to right rear and slightly down. The fan brands, many have a favorite. Some blow so hard it sounds like a shop vac under you seat. I had good experience with the Atwood 450 cfm 4" fan , you could hear it running but also could tell it was moving the hot air from rising straight up to the seat. Got mine off Amazon.com.
271,866
Here is my bilge fan installation, literally from 6 years ago....
Here is what I did afterwards to seal everything up.
Reactions: Rayger143
Y
Yakman
127
314
WA
I couldn't get a good picture angle on the fan. It isn't obstructed but from the pic it would appear it is.
StewB
StewB
720
3,340
It was 88 degrees today and my first good test of the 7" under-seat fan install I posted above. Worked like a charm and the fan was nice and quiet. The better test was yesterday at 88 when my son spent several hours tooling around with a passenger in the back seat. He's 6 feet tall and a big guy. After the trip he said he felt the heat from above, not below, and was very comfortable.
One thing I hadn't mentioned - I use hunting seat cushions (Wally Mart, Cabelas, S-Warehouse, etc.) on the back seats when adults are riding. I can't remember who posted about this, but it changes the backseat experience for adults. Your knees don't bump up by your chin.
I know, pictures or it didn't happen. Please spot me this one unless you're going to make every adult post photos of their back seat experience. Peace out.
WagginTail
WagginTail
1,577
5,827
SC
I agree. Two great, cheap mods
