Hey guys I wanted to share my Boondocking / Camping lighting solution. All in under $ 80. I bench tested several times before final assembly. Works awesome !
I carry a 12' custom tripod for hunting so I set up a removable bracket with a 1" solid aluminum round bar.(Last pick) . That's a very handy attachment. Multiple uses may add removable deer winch attachment in the near future. Each stub out holds over 200#
Back to the lights:
24"- 3/8" x1" aluminum flat bar
12"- 1" aluminum pipe. Think it was 1/8. Used 1/2 for top & bottom
6'-3/4"x1/8" aluminum square tube (Slides inside 1" aluminum pipe i.e. removable)
Lights: Exzeit Waterproof LED Work Lights for Truck, 150° Flood Led Light Bar
Carry extra 100 amp/hr battery & solar panel. Incredible light output. I will post the actual amp draw I think it was 5 amps in total .
Everything is collapsible and stores unnoticed on the buggy. This is the unfinished version. I will update the pics and performance numbers in the near future.
Best of luck !
Rudy
Back to the lights:
Best of luck !
Rudy
