P1000 Boondocking /Camping Lighting
rudyeng
109
554
Florida
Hey guys I wanted to share my Boondocking / Camping lighting solution. All in under $ 80. I bench tested several times before final assembly. Works awesome !
I carry a 12' custom tripod for hunting so I set up a removable bracket with a 1" solid aluminum round bar.(Last pick) . That's a very handy attachment. Multiple uses may add removable deer winch attachment in the near future. Each stub out holds over 200#
Back to the lights:
24"- 3/8" x1" aluminum flat bar
12"- 1" aluminum pipe. Think it was 1/8. Used 1/2 for top & bottom
6'-3/4"x1/8" aluminum square tube (Slides inside 1" aluminum pipe i.e. removable)
Lights: Exzeit Waterproof LED Work Lights for Truck, 150° Flood Led Light Bar
Carry extra 100 amp/hr battery & solar panel. Incredible light output. I will post the actual amp draw I think it was 5 amps in total .
Everything is collapsible and stores unnoticed on the buggy. This is the unfinished version. I will update the pics and performance numbers in the near future.
Best of luck !
Rudy
IMG 20221030 091102489 HDR
IMG 20221030 091439465 HDR
IMG 20221030 092013365 HDR
TripleB
TripleB
11,777
100,235
Caryville, Tennessee
Back to the lights:
Best of luck !
Rudy
Fancy
rudyeng
109
554
Florida
I wish eliminate the generator and additional gas/Coleman fuel. Everything is solar & Battery powered. I should have transitioned years ago. The output on the led lights is amazing. I will post a pics once everything is set up 100%. Still balancing the amount of amp/hr per day -vs- Solar panel & battery.
The solar panel & Battery upfront cost varies form $ 200 to $ 600 for lithium phosphate 100amp/hr. You can do the Walmart deep cycle setup of around $ 80 then charge at home as need. No solar panel required. You can easily get 4 nights out of the basic non solar setup. Say 4.5 hrs/night. Any cheap solar panel can extend your range
1667155517244
207,989
Back to the lights:
Best of luck !
Rudy
I just use the camp fire for light. HA!
rudyeng
109
554
Florida
Lights worked better than anticipated. I'm going to throw in a on/off/all rocker switch to lower the amp draw. This will allow me to use 1 or 2 lights as needed. The one light option works great and will draw only 2.2 amps but it's nice to be able to light up the area if needed.
crewcabrob
crewcabrob
1,029
4,038
Omaha
Look like it works really well. I'm looking for a light that I can take from white to red for better night vision preservation.
Rob
crewcabrob
crewcabrob
1,029
4,038
Omaha
Yep, I have a couple of Fenix lights. I have been using Zebralights.com for my headlamps for quite a few years.
Back to the Original Post: I take it that the $80 you have in to your project is for the lamp heads, wire, aluminum but doesn't include the power source?
Looks like a ton of light...
rudyeng
109
554
Florida
Correct batteries not included. You have 2 options. A cheap $ 80 Walmart deep cycle battery or an advanced lithium phosphate battery setup. Both can be charged at home prior to the trip.
The math is pretty simply based on the 4.4 amp draw I can get 22 hrs (Say 20 hrs) out of a 100amp-hr battery but I really only use the lights at night for 4 hrs + 1 hr in the morning say 5 hours/day. I can light up my camp for 4 days. The lights are so bright I can turn one off and get 8 days out of the system. The mount height facilitates great light coverage.
I actually added a 220W solar panel and lithium phosphate battery setup to extend my stay as needed. I can charge my phone, gps, and other life safety devices without having to worry about power consumption.
crewcabrob
crewcabrob
1,029
4,038
Omaha
Sounds like a great setup!
bumperm
bumperm
1,849
6,649
Gardnerville, NV
A little OT, sorry . . . just to add, I have a couple of Zebralight headlamps also. When I bought them 4 or 5 years ago, to my thinking they were the best thing going in small headlamps - nicely made. With the continuing incremental improvements in LEDs efficiency and light output, I'm sure they are better still now. One thing that doesn't appear the have changed much, if at all, is the complicated user programming interface for changing 2nd layer brightness levels and more. "four double clicks" to do what?? 🤔 Fenix'user interface is simpler and model designs are more prolific.
One new Fenix feature, I like a lot, is the sealing method for the outside micro-SD charging port. Instead of a rubber plug, which can get torn off or is fiddly to use, there's either a rotating collar or part of the light body rotates a few turns to reveal an O-ring sealed port - slick design.
rudyeng
109
554
Florida
I use the Fenix during my AM/PM walk to my tree stand. It's a fantastic light.
