Talon Bouncy Throttle
HUCK
HUCK
1,047
2,314
ARIZONA
I have trouble holding steady with gas pedal on slow rocky trails. Has anyone found a fix or a tip to help prevent the bucking bronco syndrome!
Buy a ThrottleMax . I took the one off my Pioneer 500 and it fits and works perfectly . Stops the bouncy throttle problem 75% .
Code54
Code54
583
626
Hurricane West Virginia
Are you still happy with the ThottleMax from you 500 on your Talon? Working ok?
That Talon is TOUCHY
bionicman
37
49
seattle
throttlemax helps but while owners dont want to hear it other than 'you'll get use to it" ' the throttle bounce'
but I custom made a bracket & tied a Saint 10 spd mountain bike derrailur adjustment that effectivly increases rpms by 500-700 rpm per click & mounted on the shifter
works & at no point hinders full throttle applications
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
I’m interested in more information about this.
is it setup as a low speed cruise control?
Reactions: CID
dpnorth
dpnorth
North adventures south
159
408
Crawfordville FL
www.youtube.com
  2. Other Brand
  3. Talon X
Fits the Talon? Jeez I've been waiting months for them to launch one for the Talon. I'll just go buy the one for the p500!
Thanks for telling us!!!
Thats what I did. Helps a bit. Not a perfect fit, but works. I beat it on w/ a deadblow mallet, and drilled a hole through the top-right corner of the pedal face and throttlemax. put a stainless allen panhead in it with a nylock nut. Can keep your right-foot flat on the floor and still apply throttle. helps a lot in the chop, and crawling through tight trails. I will say its like a 75% reduction in chop/bounce. still happens tho.... I am going to try tightening up the slack in throttle cable. Sounds like a good suggestion to me.
If its anything like the pioneer, its part of the learning curve. Your foot has to get trained and use to it. It wont take long. Although ive never used one, I think some people use a throttle max to help. Keep riding!
Exactly correct, I have both and they are the same. Time in the saddle is the fix.
dd963
dd963
10
10
Pennsylvania
i added 8lbs more springs to my gas pedal to make it harder to push and put shock therapy kit on the shocks. now i very rarley have the throttle problem anymore
dpnorth
dpnorth
159
408
Crawfordville FL
www.youtube.com
  2. Other Brand
  3. Talon X
^^THIS!!!! More information on the spring/setup you used please!!! I started looking without much luck. I think this is the major ticket.
Plz on some pics too if you added an additional spring in conjunction with the stock one. :D
dpnorth
dpnorth
159
408
Crawfordville FL
www.youtube.com
  2. Other Brand
  3. Talon X
I don’t think it is anything like the P1k, TBH. I ride with a couple buddies who have pioneers. They can blip the throttle on purpose, just to make some racket with their exhausts and it doesn’t snap anything like the Talon. The thing will break your neck. H or L, doesn’t matter. Maybe its a break-in thing, but 25HP difference seems to matter.
bionicman
37
49
seattle
forum doesnt allow picture uploads ~ in summary I custom fab ed up a bracket to support the actuation & tied into upper mounting bolt for upper throttle assembly
setup the first couple clicks take out cable slack thus no rpm adjustment but third & fourth click are the ticket for rock crawling/trail speeds
at no point of 0 to 4 click adjustments does it hinder a knee locking throttle application in those situations requiring additional motivation
89% of ALL youtube utv fails are a DIRECT result of the driver stabbing the throttle not cognizant of contact patch / traction management implications. period.
the setup works to approx 3/8 throttle & at that point runs out of adjustment but dont have a need for 55mph 'cruise control'....
think Teraflex Jeep Wrangler Hand Throttle Cable Kit 4870402 (97-06 Jeep Wrangler TJ)
Reactions: Sheetmetalfab
We all upload photos regularly. There may be a timed restriction however for new members.
bk5r
38
59
Congress, AZ
I went with a little simpler solution. I made piece out of 20 ga SS spring steel. About 7" X 2" with a cutout to clear the "trans tunnel". Attached it to the gas pedal with two screws at the groove on the pedal. Really took the bounce out of the action.
7,141
27,151
Pictures please!
5,027
22,465
I rest my foot against the 'transmission' hump - the problem hasn't occurred for me and the ROCKY Mountains aren't noted for their smooth trails. :oops: Note that I learned to drive that way to keep from squirting the accelerator pump on carbed engines, hold yer foot still or get terrible mileage, so it's a natural extension of that lifelong habit. #oleguysrock
DRKnight
136
269
Yuma, AZ
you can adjust cables, add spring or door hinges ect. but what really works is a heal support... 20191007 125335
Reactions: TripleB
Lil_Steve
Lil_Steve
544
2,107
Gilbert, AZ
@jasond recently posted about a heel support in his thread and I decided to try one out. I've received and installed it but haven't had the chance to drive with it yet. I did make vroom vroom sounds trying it in the garage though. :cool:
GreenTX1000R
GreenTX1000R
79
98
Texas
What I do is use manual mode and shift to a higher gear and it helps some.
