P500 Brake Pad installation?
Mudder
Mudder
NTC Ambassador of Walls
11,643
87,838
66,816
The fronts are same. Rears are on the driveshaft.
Both are fairly easy.
I think the rear caliaper turns to retract while the fronts push in.
Reactions: trigger and Mudwing
177,981
And there's a tool for the rears instead of jabbing yourself...or so I've read. ;)
Mudder
Mudder
11,643
87,838
Yep, Just got the odd little tool in mail, thanks to @DG Rider
Linking other found info. P500 - Brake pad wear info/brass pads
Thanks all
D8664F9A 425F 44C2 8A60 4DE18A52F0C3
Mudder
Mudder
11,643
87,838
Fronts easy, rear a PITA took the rear skid plate off for better access. small pad shims/plates fell everywhere LOL, Fronts worn out, rears have lots of pad left. Taking pics along the way to add to linked thread.
P500 - Rear brake pads
Reactions: trigger
