P500 Brake Pad installation?
NTC/TAP Transition Member
11,885
90,612
68,424
The fronts are same. Rears are on the driveshaft.
Both are fairly easy.
I think the rear caliaper turns to retract while the fronts push in.
Reactions: trigger and Mudwing
196,617
And there's a tool for the rears instead of jabbing yourself...or so I've read. ;)
11,885
90,612
Yep, Just got the odd little tool in mail, thanks to @DG Rider
Linking other found info. P500 - Brake pad wear info/brass pads
Thanks all
D8664F9A 425F 44C2 8A60 4DE18A52F0C3
11,885
90,612
Fronts easy, rear a PITA took the rear skid plate off for better access. small pad shims/plates fell everywhere LOL, Fronts worn out, rears have lots of pad left. Taking pics along the way to add to linked thread.
P500 - Rear brake pads
