Hello everyone my name is John (nickname Petie). I found your site last prepared to preform my first oil change, and the post was perfect!! Thanks Paula!! Okay here's the problem.... I completed the oil change and upon replacing the three bolts that secure the oil filter cover I snapped off on of the bolt heads (the bottom one to be exact!! Now I'm pretty sure I can remove the broken bolt by tapping it out but my question is, I do not have room between the bolt hole to get a bit and a hammer in there to punch it, much less a drill. Has anyone removed the gas tank to fix this problem, or is their a better way that I don't see?!?! Any help would be appreciated!! Thanks in advance!!
