P1000m3 Bummed with my 1000 LE: I-AWD malfunction light is on
hammick
35
55
Montana
My new '18 LE has less than 20 miles and the I-AWD malfunction light is on. I'm bummed. I'm on vacation with it and it's gonna be real time consuming to get it to a dealer. When I put it on my tilt trailer I used the hill hold feature and the malfunction light was not on. When I went to take it off the trailer the light was on. I've ridden it around up to 50 mph with no luck. I've ridden in reverse. I also disconnected the battery cables for 15 minutes and then put them back and went for a ride. No luck.
Anyone have an advice? I'm assuming the two sensors are located on each end of the front differentials. I've checked those wire connections and they seem solid.
Thanks.
Reactions: sharp and 100Acre
104,857
Thanks.
Sorry to hear about your problem, but welcome to the Forum
Reactions: sharp
hammick
35
55
Montana
UPDATE: Problem fixed. The connector for the passenger rear sensor was disconnected. Must not have been seated all the way at the factory and came undone during trailing. Once I connected it the malfunction light did not go away. I pulled each fuse, reinserted them, turned on the ignition and then the error went away. I disconnected the sensor again to confirm that was the issue and the malfunction light came back. This time I didn't have to pull any fuses. Strange.
Anyway I avoided a nervous breakdown.
HondaTech
The MIL light will stay lit every time even if the key is cycled if the system detects a fault when error checking at first power up.
It didnt go off when you plugged it back in because the ECM was still showing that was a current code.
It will only go out if the problem is corrected and the key is cycled, but the code will be stored in the ECM no matter what until it's cleared from memory.
When you unplugged the sensor again, the ECM recognized the problem immediately and illuminated the MIL. I assume you plugged it back in and cycled the key then the ECM didnt see the problem when the key powered everything on, thus the MIL stayed off.
