![Tflynn](/data/avatars/m/1/1412.jpg?1431175688)
Tflynn
Not a liberal
Today I got started on a project I been wanting to do for awhile. I'm going to weld in some steel plate to the bumper so I can have a good place to mount a shackle/tow hook to the front. Check out my shackle mount I'll be using if you haven't already-
Overly complicated Shackle mount
Ok in the words of Brisco Darling, let's jump in and hang on! (For the Andy Griffith fans)
After measuring on the bumper where the steel will go, I cut off my piece. I'm using 3"x3/8" flat bar for this project.
I'm guessing either side will need a 15 degree angle so I'll start there. Notice the vice on the saw is rotated 15 degrees.
So here's a 15 degree angle on both sides of a 16.5" long (measured on the short side) piece of flatbar-
You may also notice the marks on either end that are 2 1/8" in. That is where I need to put a slight bend. Protractor says 20 degrees, so that's what I'll do!
These magnetic angle finders are handy. After I adjust for zero (my work bench ain't exactly flat) I can figure where 20 degrees will be, and I mark it on the gauge with blue tape. Here's the bar after heating and bending. Notice the crescent wrench for added leverage while bending.
Using the angle finder helps me get identical bends on both sides. Once that's done, I can do a test fit and maybe you'll finally understand what the hell this is going to turn into!
That's it for now. I'll let you know when I make some more progress.
