bumper mod
spifyd
spifyd
419
178
newhampshire
wanted to spruce up the bumper a bit. I kinda like it.
slowdryrider
slowdryrider
575
785
Canada
I like the little turn signal lights as well. Do you have signal lights and if so did you buy a kit or your own fabrications.
Finkleshtine
Finkleshtine
38
21
Windsor, CA
That's sweet, Very nice job! It adds just enough to stand out, but still looks factory!
spifyd
spifyd
419
178
newhampshire
made my own turn signals. those are led marker lights set of ten on eBay pretty cheep they go in a 3/4 hole.
a 3 way switch on the dash. and a 9 dollar heavy-duty led flasher from advanced auto parts.
all very simple. I found last summer I spent a lot of time running around town and it was a pain in the a## zipping down the window and sticking my arm out at traffic light.
slowdryrider
slowdryrider
575
785
Canada
Nice I'll have to try it again.I tried in the summer using led clearance lights and a turn signal switch from a big truck and used a led flasher but for some reason I couldn't get it to flash. The lights would just stay on and not flash so not sure what I was doing wrong. Kinda lost interest in making them untill I saw yours ,now its got my interest sparked to try again.
Like it someone finally showed some initiative.
I was doing nothing more than thinking about doing something to make the factory bumper a bit more effective at being a bumper and looking more aggressive. Haven't figured it out for myself yet though.
jimk
jimk
24
9
spifyd, Did you run turn signals to the rear? If so, could you post pics of that? What kind of switch did you use?
spifyd
spifyd
419
178
newhampshire
yes both front and rear I used a duel poll double though switch. I made a wiring diagram its on my work computer. I will post it tomorrow when I return to work.
spifyd
spifyd
419
178
newhampshire
you can see the rears here same 1" marker lights.
Spifyd, can you take some close ups of that rear winch???
I like that... Translation, I am going to copy you at some point.
spifyd
spifyd
419
178
newhampshire
here ya go. i had them from when I put it on. its just bolted to the p4 roll cage mounts.
jimk
jimk
24
9
I like that. I think I am going to borrow your idea. What gauge wire did you run for those?
spifyd
spifyd
419
178
newhampshire
don't really know what ever came with the winch. the axillary battery is right in front of it.
Most come with @8-10' of 4ga.
Any longer and you might need a larger wire, it depends on the amp draw of the winch. I wouldn't go any smaller though they have a fairly high amp draw.
68,409
Stick to standard. It's no longer maybe even shorter to wire it to the back vs front.
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
I like the rear mounted winch. I just bought another one to do the same thing. Do you have clearance issues with the dump bed?
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
What kind of shocks are you running? How do you like them? Your rig looks awesome!
duwops
duwops
231
46
Spifyd, very nice set up on both. That bumper mod seem like the ticket for heavier brush riding. The longer I ride the more I want to add signals. I get out on the country roads around here and my concern with hand signaling is many of today's drivers think your waving to them. I also have problems with autos getting right on my arss. Are those signals bright enough to get the attention of followers so they are clear on your intention for direction.
spifyd
spifyd
419
178
newhampshire
the lights are plenty bright. I probably could of used just one on each corner. I put them on for the same reason plus its to much work to zip down the window at every intersection.
