Need reviews on DEI's 3 inch auxiliary fan kit with there heat shield? Worth the money?
R Rob_-A New Member May 20, 2019 3 9 3 Northeast Pennsylvania Ownership 1000-5 May 20, 2019 #1 Need reviews on DEI's 3 inch auxiliary fan kit with there heat shield? Worth the money? Reactions: sharp
BigOL3 Well-Known Member Lifetime Member Oct 27, 2017 2,994 8,920 113 Deep in the heart of Dixie, Kentwood, La. Ownership 1000-5 May 20, 2019 #2 I can't see how it can possibly be worth more than $400! You can DIY for less than $100. Reactions: sharp
Bradley-Thornton Well-Known Member Lifetime Member Nov 6, 2017 684 1,649 93 Hattiesburg MS Ownership 1000-5 May 20, 2019 #3 Post 71 and 75 you can skip the ink bird if you want it just to run all the time and simply the install. P1000 - Tried and true cab heat fixes-2018 Reactions: sharp and BWAF
R Rob_-A New Member May 20, 2019 3 9 3 Northeast Pennsylvania Ownership 1000-5 May 20, 2019 #4 Bradley-Thornton said: Post 71 and 75 you can skip the ink bird if you want it just to run all the time and simply the install. P1000 - Tried and true cab heat fixes-2018 Click to expand... Thanks Reactions: sharp and BWAF
Bradley-Thornton Well-Known Member Lifetime Member Nov 6, 2017 684 1,649 93 Hattiesburg MS Ownership 1000-5 May 20, 2019 #5 Rob_-A said: Thanks Click to expand... I see you are new welcome also that whole thread should help. Reactions: BWAF and sharp
