Talon Cage wall thickness?
BiGPimP
0
Illinois
Anyone know yet the wall thickness on these cages? I was looking at an X at my local dealer. The metal gusset at the top of the a-pillar seemed a bit thicker than a soda can. I found a weep hole on the underside of the top tube where the b-pillar meets and shined my light up in there. Seems awful thin. I know that with larger diameter, you can use thinner material and get the same strength(moment of inertia). Just wondering if anyone can chime in.
Gator
Gator
The Most Unknown Member
2,474
10,381
Louisiana
In theory you could use thinner material.
In real life the thin wall is easy to dent. The dent reduces your strength exponentially.
Kilo427
Kilo427
1,543
6,439
Believe Pioneers are .066 give or take
120 dom vs stock
CBFFCCF9 AB76 44FD 807B 089F567BE995
39,079
I didn’t write down the measurements but it the pioneer 1000 uses three different wall thicknesses in the cage. And all of them are thin. Possibly the same way with the Talon
0c7f75cad6217d7bf24d7e78ee438f10
I chopped 4.5” out and sleeved them with the longest piece I could fit in all 6 pillars....
37133985ab4c0e702a312c6a4300d095
Angarlo
Angarlo
21
Illinois
Did you use a 1.5" OD DOM tube for sleeving the pillars?
Anyone look into beefing up the attachment points where the cage meets the frame?
