Camber issue after bracket lift
rsmcmurru
5
Mississipi
So, I recently installed the Rough Country 3” bracket lift on my 2016 Honda Pioneer. Now I have approximately 1/2” positive camber on both the front and rear tires. I drove the machine for about a mile or so thinking the suspension would settle out, but no luck.
Does anyone have any suggestions to a fix?
Reactions: TxDoc
SuperATV
SuperATV
1,236
8,601
Madison, IN
www.superatv.com
Giphy
That kit give you lift by pushing your arms down...giving you positive camber. The only way to fix it is with adjustable A-arms. Shoot me a PM if you decide to pull the trigger, and I'll get you the current member discount code. Here's a link:
rsmcmurru
5
Mississipi
Yeah, all my research points in that direction. I have been on the SATV webpage browsing, and it looks like I am going to have to make the move. If you can provide a member discount code that would be awesome.
N
Nathan hunter
Illinois
What A arms do i need for front and back?? I have the 3” bracket lift and 30” tires. I don’t really want to go much higher. Any help would be great
P1K5Dave
P1K5Dave
2,170
8,109
Petoskey, MI
Go with 3" lift arms and ditch the brackets. Your ride will improve and you'll be moving your front wheels to better fit without rubbing.
Then plan go to aftermarket shocks and transform your ride quality (if you're running the standard shocks.)
Robobrainiac
Robobrainiac
2,458
8,564
The SuperATV arms will not add lift they just add adjustability.
The c fab arms will replace the bracket lift entirely and still give you 3" of lift and adjustability.
Both sets will also give you arched lower arms that give you additional clearance.
Robobrainiac
Robobrainiac
2,458
8,564
On a side note:
I have not seen or heard of this much camber resulting from the bracket lift. Could you please post some pictures directly from the front and rear level with the tires?
N
Nathan hunter
Illinois
I thought satv offered both?
Their 6" kit includes 3" arms and 3" brackets, doesn't it? Do they not sell the 3" arms without the brackets?
I’m not sure. I just bought the 3” bracket lift and spacers for the back. Do i need them for the front too??
Reactions: Smittyp
105,367
Get rid if that bracket lift. It fucs with the geometry if your rigs suspension. Like said before, get the SATV arms. then if u dont have them already, get some aftermarket shocks and use the pre load on the shocks to get your lift. Your better off in the long run.
208,013
I'm surprised they're haven't been a of law suites over the lift kits.
