P500 Can a wheel be reversible
SP82
SP82
101
356
CA
In most cases no. The lug nut holes would be seated on the wrong side , the mounting flange of the wheel wouldn’t sit flat to the hub and it would most likely rip the oem valve off on the brakes (unless you were running larger rims or flush mounted stems ) but for many safety reasons I’d say no , unless you were running a spun alloy atv style wheel (think Douglas or ITP L quad wheels ) for sure not oem or any major stamped steel or cast aluminum wheel
Sent from my iPhone using Tapatalk Pro
63,409
Totally agree.
While I have done it in my ATV days. No way in hell would I do it for a SxS for any other reason then limping back to the truck.
lee
lee
Village Idiot
2,327
13,032
Springfield Ohio
If you have a Ferguson tractor then yes.
1AC7594E AA96 49B8 A1C0 CB1BB7D983C9
But generally no.
The lug nut holes are set up with a shape that springs in a little when you tighten the lug nut so it doesn’t come lose.
If you reverse the wheel it doesn’t work and it will damage the wheel.
Keebler
Keebler
242
832
St Charles, Mo
Thanks for all the info. A quick visual check looked like it would work, however I agree with the lug nut tightening aspect. Rims are too cheap to take a chance of loosing a wheel during a ride.
