P500 Cargo basket aluminum
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Yes, rubber style rough texture, sprayed one coat let cure 72 hours, sprayed second coat, even covered up some of my not so pretty welds. Guy at store said just needed metal clean and roughed up so it would stick really well. Haven't had anything in it yet. But seems to be really hard.
I really like those rims. Can you share the make/style you using on the P500?
RobertC
24
Louisiana
Ha, think those were my best deal yet. Seen a local add for Honda P700 rims and tires. Traded him a old Hoyt bow even for the set. Came from a 2017. Sold my factory 24" week later for same price I was asking for bow...
Reactions: alloutdoors
Mudder
Mudder
NTC/TAP Transition Member
11,865
90,388
@iceboundzeke , like the security box lid, can still have flat top for other cargo, found this pic.
95D01C7F 8155 4AAD A493 C86E1E31A822
Mudder
Mudder
11,865
90,388
Finally got side truck box, used 2 in pvc pipe for needed spacer. Gained a hole to carry shovel. Used provided box legs for basket trim. Box at Lowes for $149 until 3/20/18. Never ends...
81A9C839 1398 4E57 959F 64FE28122E23 CD0C0D70 85E5 4204 8880 693910B259D1 5CBE0C72 DC21 43B1 BF67 266327D8B609
Mudder
Mudder
11,865
90,388
That flat OEM rack offers so many options, but heard many pass up the P500 because of the rack. Many good mod ideas throughout this forum. If theres a will, theres a way.. Had a barn bird start building a nest under my box today, guess he liked it too!
Great idea on cutting back the basket rail! May do the same now.
The black basket with the camo looks sharp!
BigOL3
BigOL3
2,997
8,921
Mudder
Mudder
11,865
90,388
FYI...Aluminum cargo basket on sale now till Saturday, 4/7. , $79, Northern Tool.
Reactions: RumpRocket
L
LADucks
19
Louisiana
You guys that have used the Harbor Freight/Northern Tool aluminum baskets... does it come assembled? It would work great for the roof of my Honda 700-4 if I could shave about 3 inches off the end before I put the end pieces on. Is the hardware already on the ends or do you attach them after the fact, as in after Ive cut a little length off? Is it that simple or would it be a little more intensive?
Reactions: Mudder
Mudder
Mudder
11,865
90,388
873EC185 F2BA 4A5B 9042 9D7E419C78A0
Basket is one piece, unused hitch tube is a separate bolt on. Corners joined with pop rivets and could be easy, but bottom frame might be more difficult. Heres a close up of bottom frame if it helps.
Reactions: trigger
L
LADucks
19
Louisiana
Could you give me an exact length of exterior? Outside to outside of the box? I might can actually squeeze it. Thanks!
Mudder
Mudder
11,865
90,388
@LADucks , Mine is from Northern Tool, likely same, just measured total outside dimensions 49 1/2, W, 22 7/16 L and 8 tall. Bottom pieces are welded to perimeter frame. Disregard aluminum diamond plate support legs I repurposed for side trim. Followed forum rule “pics or it did not happen”. LOL. PS, like the dual rulers with metric for helpers not schooled in fractions.
but here is HF specs, but may be their Inside measurements.
  • Cargo platform: 47-1/4 in. L x 20-1/2 in. W x 6 in. H
56930191 D67B 4215 AEA9 B00C881CF578 91A104D5 8F7F 4512 A98A EE61E6CCB658 1E25F692 BD5F 4EC6 84AD 3E1A683DE0F3 0E6A4FEE FC87 44E9 AFED BC97FE7B1034
