P500 Cargo basket aluminum
luckymike
luckymike
144
322
michigan
Black husky box was on clearance at home Depot last week.picked one up for $102 OTD.
Reactions: Shadesmn
Russ989
Russ989
22,565
146,497
RobertC
24
Louisiana
Got tired of looking at racks/ baskets that didn't mount or fit the way I wanted, so I built my own
Image Image
RobertC
24
Louisiana
Thanks, Russ989 and rump rocket, Bought my p500 in December, knew I wanted/needed rack but just didn't like any thing out there. Like to think I am pretty good with wood projects, so I tried my luck with a big metal job. Some 1 in sq tubing and expanded metal and several late nights in shop, finally finished, 2 coats with truck bed liner spray. Mounted and ready to test it..
Shadesmn
Shadesmn
505
959
Ramsey, MN
2 coats with truck bed liner spray. Mounted and ready to test it..[/QUOTE]
What type of bedliner material did you use?
Reactions: RumpRocket
RobertC
24
Louisiana
What type of bedliner material did you use?[/QUOTE]
Bought 6 cans of spray can Bedliner coating from a pain't supply house. Sanded metal down with 80grit paper. Soaked and wiped down with cleaner. Was gonna have line x do it, but quoted me 375.00 to spray!!! Wow!
Reactions: Shadesmn
Shadesmn
Shadesmn
505
959
Ramsey, MN
Is it a rubberized like finish? I used some left over herculiner bedliner material on my old forman racks and that stuff lasted forever. It was a bit rough on texture though the way i applied it. I too got a qoute from a local place for my box but he said i needed to have a epoxy coat on it first cuz he wont spray bare aluminum. Not gonna pay two places to do it so I'll be doing it myself as well.
11,312
84,034
Thinking about cutting an extra horse stall rubber mat from barn to lay in bottom of tray, pretty thick stuff. Worst part would be cutting it. Anyone else tried it?
RobertC
24
Louisiana
Yes, rubber style rough texture, sprayed one coat let cure 72 hours, sprayed second coat, even covered up some of my not so pretty welds. Guy at store said just needed metal clean and roughed up so it would stick really well. Haven't had anything in it yet. But seems to be really hard.
Reactions: Shadesmn
156,144
Basket looks good and I hope it sticks for you. I don't feel so bad now, I actually paid $400 to have mine Line X'd and there were a lot of corners and details. The price is due to the prep on the bare aluminum. He had to scotch brite the whole thing thoroughly, wipe it down with acetone, don't touch the metal with your fingers at all, then you have about 15 minutes to hit it with etching primer or the protective properties of the aluminum start kicking in again. Anything I make out of diamond plate now is the black stuff and already sealed. ;)
Toolbox chrome
RobertC
24
Louisiana
Nice box!!!! Yeah hope it does. But if I have to respray in a year or so, still only out about 80-100 bucks. What's sad is buddy had Toyota truck bed sprayed by same guy and it was only a little over 500.00. Just didn't sound right.
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
11,312
84,034
Just drilled 2 holes thru box frame straight down into flat section of pioneer rack. Jsed nylon nuts for underneath, but very tight fit for wrench. If doing it again, would use a U clamp on outer sides for easier access. Saw where some one used heavy duty cable ties.
Reactions: GRANITE
luckymike
luckymike
144
322
michigan
Make a couple of straps to go under the flat areas of the rack.drill and tap.drill holes in basket in same location.screw down
15181977190401255734741
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Great looking rack. I would have jumped on something like that if available anywhere...
JCart
JCart
897
2,024
Kamloops, BC Canada.
Have a custom one being made up will put up pix when done. Basically aluminum tube sides and a small hoop part way up the cab. Will bolt to stock rack and I’ll put 3mm black UHMW sheeting in the bottom. Simple light strong for packing larger chainsaw and other work gear.
j
Reactions: Chooglin
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
Reactions: Mudder
