P1000 CATVOS Pioneer 1000, 3 Inch Lift Install!
This is not a full step by step for the install but it should be a big help for anyone performing the task alone. Plan for 5-6 hours.
Unpack the box and check for everything. I was missing the instructions so they emailed me a copy.
8f27ecc47cf0d4edb22ec917d7007fda
Jack it up and remove tires.
848d514df0f01464f8f725178c1bbfc1
C0f6d4460752847d2b928626ffbe3c40
I'll show the front first. Remove the lower shock bolt.
Bf86d27b310589eb2cb9e17460aa07f9
I then removed the hub nut. Throw away the cotter pin. Plan on using a new one.
555b04ab0bbf20e029bd0af4369bf53b
Let's start removing the brakes now. Remove the two caliper bolts and slid the caliper off.
Acd8863056e8b706283882367e7a0690
Store it in a place where it won't be hanging by the hose.
C0f0bafed5e0019bbca573335c61e5b5
Then remove the brake pads and be caliper bracket. These bolts are tight, Honda used thread lock compound.
99ef5ef385032a49d06d096417f23d34
Here's what it looks like with the brakes out of the way. And with the caliper bracket removed, the hub will slide off.
6fb131ab96aff640be67f28b8d8b5433
Next remove the lower A-arm from the frame.
84ced5f5d2fcc02dc01413689cf85877
With the lower A-arm detached, you can swing it up high and they axle will come out of the knuckle. Now you can access the ball joint nuts.
02d5063b6245e26bcef34f24390b1726
After you remove the ball joint nuts, you will need to use a mini sledge to bang on the arms to free the ball joint from the knuckle. Don't hit the threads, just hit the arm close to the ball joint. Here's a pic of the lower arm removed and the upper arm detached from the knuckle. Leave the tie rod attached and swing the knuckle out of the way.
3b1559ece31a7f1555ca993fd05eff06
Now remove the upper A-arm. It is held on by one long bolt that goes thru both joints.
08d3982f5f7681bf87a62560c19c5a0c
You will need to remove the upper ball joint and re-use it. A press will help greatly with this. A hammer could be used but it could be damaged.
44bad75d866e7594da1fa5480c099163
Press the joint into the new arm
A285adf4e7a90fa9c2b20085e037d95b
Find ya some of this... You can see the left over red loc-tite that Honda used. I put some on all threads that Honda did.
1ea0d074b7262d224a035051cdc950dc
I used the thread locker on the upper arm frame mounts. Here's a pic of it installed.
46130370f8fa6d74ca4035eaa672305b
Now attach the upper arm to the knuckle
5c451e2384f390ceaf2fc9a4edf47d8c
Now attach the lower A-arm to the knuckle
7cfd44e675b2f9bc4c782e4f06a6354e
Use new cotter pins!
Efb6bbb4d2d403359c6836e4f6f73193
Now you can slip the axle back into the knuckle by lifting the whole assembly up.
D6522aa798a9597785c8392175b49b45
Here's the lower arm attached to the frame.
800f37fa6e38e4625d6e289a46bb2a30
Now it's time to attach the shock to the upper A-arm. I had a problem here, the shock mount was too narrow for the shock. It was only like this on one side.
35dee1f9657dc34d2af39544aa966e97
A little massaging from a mini sledge and repainting, it fit ok.
Fc45c3880c578812980fd84ba23a45dd
Now install the hub with a new cotter pin
E569b9a9daa49acfd4ce0e3b24b66981
09d8c8a81787fd93ef4a1fe1ead0a41c
Now you can install the caliper bracket with thread locker on the two bolts.
F3a652fdf4cdbb074290f9e7ba2233d8
0c96a67bec2081b98d4e1dfaaec98e3b
Next is to install the brake pads.
F636e756caaf456398e39f22aac61bbd
Then use medium strength thread locker for the caliper.
E1141d85e7013dcfd41eeb73d20b0724
3813501e73c700bbe3febaca85672417
Next step is to secure the brake line. WHAT?! $1500 dollar lift and no way to secure the brake line. This is not good. I have plans to do something different but I really don't want to weld on the arms and weaken the metal since I can't heat treat it. I noticed that lowes has 175lb capacity cable ties. I may use those even though what I've got on there is pretty good.
1f7839c16eeb3897f8500f3639ed2ffb
Now do all that work over again on the other side and the front will be done.
3c0624d54821407925f9cb1990b23b29
Now time for the back. It should be easier.....yeah right.
Remove the bolt for the lower A-arm to knuckle.
D3a7d0ee5b299999b3b8e63e56ac3aa8
Remove lower shock bolt
C18421df8495c4ed406609ea64d453a8
Remove the lower bolt for the sway bar
7cd3afbe9c40a1163f8d8a3fec15710c
Now remove the two bolts for the arm to the frame. It should come out pretty easy. Have a pry bar handy.
F81913268b2855b73642ea7b8176196b
Install the new lower arm onto the frame
9a48ab63a891cbf810f35555657f2fb5
Reactions: Justin7372
While installing the lower arm, you may notice that it's too narrow. You can see in this pic that the joint doesn't line up with the frame. Only on one side, the other side was good. (Did I mention that this lift is $1500?) anyway, a little time in the press and the arm fits fine.
8899d851660cb43a47be09bde11083a4
Now you can swing the arm back to the knuckle. This is the next problem. The bolt holes don't line up.
D695ea24bcab794cb8f9c71140ae73fc.
With a little prying and banging it went on.
Ok, now let's attach the shock to the lower arm. DAYUM! This bracket doesn't fit the shock. The holes are too low. I had to grind, drill, and cuss to get it to fit.
1d2abe755e8b6eb2d1e67b54668a3e08
Another pic from the other side
B3a63f47a06b73412c67f65aa8bcf5fc
Ok, after a break, it's time to do the other side just the same way.
After getting both sides done, you can re attach the sway bar. Should be easy right? Nope, again one side was good and the other side was not good. The mounting tab was not positioned properly.
In these pics you can see that it is too close to the axle.
11d9a065c66b46ec36d955a14eee72b7
F8b850aad82328375551f969801acb94
I beat it into submission and then had to fix the threads.
97718ad0d189893af28635fe9b27e24b
Here are the comparing measurements of both sides sway bar mount. They are 1/2" off!
25610a4828c91bbb66f1a605d43916c8
D42d5b05d1a4c87955c33aa994be96c9
Here's some finished pics of the install.
289e50b7d253797e7867be4939521e53
86a24ab8411a3f86863a35609dcaef9e
Now that the install is done, you get to ride for a short distance and settle the suspension. After returning, you may find that camber and toe need to be adjusted.
Front end is way out. On both toe and camber.
2bfd6d99773eed50be20bf024bcccb09
The back is out too.
5261504c5edc3bb664ad3f20766838c4
Now you'll have to remove the lower arm from the frame on all corners that need camber adjustments. You can adjust the Heim joints to correct it. It may take several attempts at adjusting and riding to get it right.
D644b1dfd62277c19714ff512be870ef
C5a9627be3d5741993b8219fe7f673d5
After several attempts, you'll get it right.
Cf0376e7c0348711ac5411001f3cbe5b
Bb183620d553eca5c7466d99170fea02
Overall, I'm ok with the fitment because I'm equipped to jump hurdles along the way. For the lack of quality on the positioning of things, it should have been a lot cheaper. I thought I was buying a top end product with a top end price. Actually, I bought a middle of the pack product with high end pricing.
I can't comment on the performance as the whole family has a stomach bug so I'll have to report back later.
I do plan on sharing the pictures and problems with CATVOS in hopes that it will prevent someone else from having the same issues.
Justin7372
Justin7372
9
Excellelent write up Joey. Hopefully CATVOS fixes those issues. You shouldnt have to deal with problems like that for the kind of money they charge.
Marine660
246
244
Awesome write up!! I am shocked at all the issues and those are things that should never happen. I can see 1/8" off but inches!
Makes me not want to consider catavos at all. Please report ride quality and how catavos responds to these quality control and figment issues.
Reactions: pct
I will report back in a week or so. I'm in GA working all next week so it will be a little while.
I have driven it around my property for ~5 miles. Things I noticed are you can definitely tell the 30" tires zap power. However, it will still spin them on concrete. With these 8ply tires, the vehicle feels more stable despite it being taller. (I experienced the same thing going to 8ply tires on my P700)
Braking seems to be affected as well, it still brakes good though as the OEM brakes are strong.
There will be more to come as I get some more seat time.
Reactions: pct
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Awesome job @joeymt33 ! Thanks for taking one for the team! Can't wait to see it in action. You'll have to carve some time out to come up and ride AMA with us as soon as your family is well and the weather warms up a bit.
Reactions: pct
A
AK_Centurion
271
330
Eagle River, AK
Great info! Bummer that the kit didn't fit perfectly. I guess there goes my plan of having it completely installed while the wife is at work. Machine is still new enough, I don't think she will notice the extra height. Mine should show up tomorrow.
Reactions: pct
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
haha, I feel ya on the wife part. I have all my parts shipped to my buddy's house, and then do all my mods over there. She has no idea that all those lights and switches weren't stock. And most importantly, she has no idea how much they cost!lol
