CB Radio?
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Check your grounds and antenna routing.
This.
Chances are you have a loose wire or exposed wire that is causing spurious emissions. Has it always been like this or just recently? if recently what is the last accessory you added? lights are known to do this - especially Chinese lights.
Reactions: JTW and Remington
11,313
84,048
Have you noticed any static from the power stearing in your CB
Might try a noise filter on the power leads if its not a loose connection. Many choices out there as it is a common problem. Similar to this.
https://www.walmart.com/ip/WORKMAN-...Yon4-qvBLRHuuvRLNc0r5lt1Y4BAMM7BoC_iwQAvD_BwE
81201C6E D0A3 46E1 9F58 066EB73676F3
