P1000m5 Changing Stock Tires Out
JGarner
JGarner
14
17
Silver City NM
Has anybody changed the Stock Tires out on a 2020 1000-5 with a light duty truck tire on the stock rims, and what was tallest tire you were able to but on with the stock suspension.
Thanks
Reactions: Isaiah
gullyjumper
gullyjumper
950
2,413
cookeville tn
Your stock rims are 14" most truck tires are 15" and larger , Im not sure if anyone makes a 14''truck tire. Maybe some one else will know for sure on that. If they do make them I might try them to.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I'm going to follow this thread because this is what I have been thinking about doing. There are a couple of light truck tires made by general and maxis that are 27x8.5r14. From what I remember I believe the biggest tire size without having an issue are 28". Hope to hear someone's reviews.
Reactions: ChadD and JGarner
ToddACimer
ToddACimer
Pioneer 1005-2
3,564
14,633
Oshkosh, Wi
I'd consider a set of DOT UTV tires. They are designed with a lower load rating and lower tire pressure. You'll get similar wear and better ride quality and traction.
ehart814
ehart814
1,654
3,643
NWPA
Thanks
There have been a few recent threads on this subject. Just search "285x75x15" or truck tires or lt tires and you will find a lot of info. I upgraded to 235/75/15 LT truck tires this spring and I am happy with them. To summarize: Super quiet on the roads, less traction in serious mud, about 1.5-2" taller than stock, have to run lower pressure due to stiffer sidewall (i'm at 9 psi).
Reactions: JGarner and TripleB
