Is there anything I need to know about charging my batteries with an isolator hooked between them?
Yes. The True.I assumed you have a automatic isolator like the True-Am?
That is one clean looking layout. very nicely done. You wouldnt happen to have a link to/or picture of the diode would you? I'm confused as to which type to buy. The booted switches look great also.What "Cleanlimps" said! If you leave the key on, my understanding is it'll run the hours up on the Hobbs meter (hour meter).
I wired my radio, so that if radio on, it turns on/off with the key switch. In the pic below, there's a little round rocker switch, below the radio, that allows me to turn on the radio when key-off. It does this by applying constant power to the radio's "positive key-switched" wire in when this switch is on. An isolation diode is used to keep the constant positive from back feeding the switched fuse block.View attachment 310335
Thanks for the compliment!That is one clean looking layout. very nicely done. You wouldnt happen to have a link to/or picture of the diode would you? I'm confused as to which type to buy. The booted switches look great also.
That seems pretty easy. With possible exception of the diode. My other plan is to remove my 10 port “switch on” fuse block and replaceHere's a crude diagram of the "key override" that lets the radio function normally, i.e. if radio is left on, it follows the key switch. However, if the switch in the diagram is closed (on), then the radio is available when key off.
All wiring for this override switch can be made at the radio, save for running a key-switched to positive wire if none is already available. Function is as follows:
Switch off (as shown), the red wire must receive it's positive voltage from the key switched source on the right (this would normally be from the aux fuse box). With ignition on, the switched positive voltage is felt through the isolation diode and the radio is on (or can be turned on as normal). With ignition off, the switched pos. turns off as does the radio.
Switch on, the +12 volts (on the left) now goes through the switch and is applied to the red "radio control" positive wire. The radio is now available. However, the +12 volts will not be seen on the right side, key-switched source, as it is blocked by the diode.
Sorry for the crude schematic diagram. Any questions, fire away.
They also make split bus fuse blocks (e.g., Blue Sea P/N 5032).Good idea. I took a 12 fuse block apart and cut the internal bar to make it 6 of each. Much easier to buy 2 sixes.
I shouldn’t need a diode at that point should I?Good idea. I took a 12 fuse block apart and cut the internal bar to make it 6 of each. Much easier to buy 2 sixes.
