P1000 Charging with an isolator
63,988
If you wired per instructions.
Then no. There is not.
Recommend trickle charging the primary. Once it gets almost charged the isolator will close (turn on) and start to charge the second automatically.
Here is a recent discussion, If you have time.
There is also some info at the end that states opposite. But I think it is wired using an alternate method.
Fdxjettech
Fdxjettech
36
108
Oakland TN
A secondary question if you please.
My soundbar has become main shop radio now. It’s powered off my switched bus. (which explains the battery charging question. ).
Can damage be done to the machine by having the switch in the on position for substantial periods of time with out starting it.
Reactions: Biteme
Prntckt
Prntckt
1,049
7,226
Altoona, WI
You could always install an override switch to energize the stinger relay for your auxilary power to avoid leaving the ignition on, to listen to your soundbar in the shop. I did this to my P1000-3 and works well.
Reactions: Biteme
bumperm
bumperm
1,851
6,656
Gardnerville, NV
What "Cleanlimps" said! If you leave the key on, my understanding is it'll run the hours up on the Hobbs meter (hour meter).
I wired my radio, so that if radio on, it turns on/off with the key switch. In the pic below, there's a little round rocker switch, below the radio, that allows me to turn on the radio when key-off. It does this by applying constant power to the radio's "positive key-switched" wire in when this switch is on. An isolation diode is used to keep the constant positive from back feeding the switched fuse block.
20211221 215040
Fdxjettech
Fdxjettech
36
108
Oakland TN
I wired my radio, so that if radio on, it turns on/off with the key switch. In the pic below, there's a little round rocker switch, below the radio, that allows me to turn on the radio when key-off. It does this by applying constant power to the radio's "positive key-switched" wire in when this switch is on. An isolation diode is used to keep the constant positive from back feeding the switched fuse block.View attachment 310335
That is one clean looking layout. very nicely done. You wouldnt happen to have a link to/or picture of the diode would you? I'm confused as to which type to buy. The booted switches look great also.
Reactions: Prntckt and Scoop
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Thanks for the compliment!
It was a Shottky rectifier diode I had a bunch of. A small rectifier diode, such as a 1N4007 - would work well ( diode ). If there was ever a non-critical diode application, this is it! Most any small signal or rectifier diode should do. I didn't measure, but current isn't much, as this is not the main feed to the radio, that's the heavier fused wire wire that connects to always on power. The small red wire is just to tell the radio the key switch is on.
The little round booted rocker switch is: switch
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Oh, forgot to add on the small "booted" rocker switch: I have two of those out exposed to the sun and weather by a small solar, Pb battery installation to run a fountain pump and electric fence (to keep the bears and herons out of a pond) - the herons like to stand at the edge and nail the fish (it's what they do). However, they'll only try it once when they get zapped! The switches have lasted for two years with no signs of wear.
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Here's a crude diagram of the "key override" that lets the radio function normally, i.e. if radio is left on, it follows the key switch. However, if the switch in the diagram is closed (on), then the radio is available when key off.
All wiring for this override switch can be made at the radio, save for running a key-switched to positive wire if none is already available. Function is as follows:
Switch off (as shown), the red wire must receive it's positive voltage from the key switched source on the right (this would normally be from the aux fuse box). With ignition on, the switched positive voltage is felt through the isolation diode and the radio is on (or can be turned on as normal). With ignition off, the switched pos. turns off as does the radio.
Switch on, the +12 volts (on the left) now goes through the switch and is applied to the red "radio control" positive wire. The radio is now available. However, the +12 volts will not be seen on the right side, key-switched source, as it is blocked by the diode.
Sorry for the crude schematic diagram. Any questions, fire away.
20211225 132432
Fdxjettech
Fdxjettech
36
108
Oakland TN
That seems pretty easy. With possible exception of the diode. My other plan is to remove my 10 port “switch on” fuse block and replace
It with two six ports. One for switch on power and one for constant hot. Then I can power the stereo off and on through a rocker switch. What do ya think?
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Good idea. I took a 12 fuse block apart and cut the internal bar to make it 6 of each. Much easier to buy 2 sixes.
Reactions: Fdxjettech
