I have struggled with the purchase of a heater for some time. Given the bad reviews of the Honda Factories and the quality of some of the others, I decided to go another route. This install was cheap and easy, plus it looks factory.
Maradyne Santa Fe Auxiliary Heaters HC-400012
Four Seasons Manual Shut-Off Valves 84706
Maradyne Santa Fe Heater Mounting Brackets MFA132
Y-Fitting 1" Radiator Hose to 5/8" Heater Hose
Ice Crusher MaxStat - Inline Coolant Bypass Thermostat for UTV Heaters
It's simple and super easy to install. I would recommend when cutting into the lines to pinch them off on both sides and also fill the heater with antifreeze before attaching the hoses at the y. This will help with bleeding issues. I bought into the Max stat idea and so far the entire setup has worked very well.
Pros---Blows out a lot of hot air -13500btu. 2-speed switch
Looks factory and seems to be made tough
Super easy to install
Cons---The middle part of the floorboard now has a heater
it does have the option to run defrost hoses I just didn't
I hope this helps someone
