P1000 Cheap Heater Solution
shinebrite
22
Glasgow, Ky.
I have struggled with the purchase of a heater for some time. Given the bad reviews of the Honda Factories and the quality of some of the others, I decided to go another route. This install was cheap and easy, plus it looks factory.
Maradyne Santa Fe Auxiliary Heaters HC-400012
Four Seasons Manual Shut-Off Valves 84706
Maradyne Santa Fe Heater Mounting Brackets MFA132
Y-Fitting 1" Radiator Hose to 5/8" Heater Hose
Ice Crusher MaxStat - Inline Coolant Bypass Thermostat for UTV Heaters
It's simple and super easy to install. I would recommend when cutting into the lines to pinch them off on both sides and also fill the heater with antifreeze before attaching the hoses at the y. This will help with bleeding issues. I bought into the Max stat idea and so far the entire setup has worked very well.
Pros---Blows out a lot of hot air -13500btu. 2-speed switch
Looks factory and seems to be made tough
Super easy to install
Cons---The middle part of the floorboard now has a heater
it does have the option to run defrost hoses I just didn't
I hope this helps someone
shinebrite
22
Glasgow, Ky.
C9395603 E976 48DA B9F5 2881BC422F2A
1FBC67DA 2CC3 40E8 944E 2B83BC9288AA
EE0CA604 7406 4463 AA87 7490701D3F25
D2C28B52 7EDC 46B8 962A 2997377F4F4E
7BD07E65 76C9 4909 8540 E12BA532D11E
749BEE7D B048 4660 90CD BE89560B59F5
55ADBE51 C771 4A2F B5C0 97D9600E44EB
steve_whiteside
55
108
San Diego
  2. Other Brand
Is the heat pretty noticeable when it is cold out? You feel the heat pretty good blowing around the cockpit?
steve
Reactions: Lady01
Vikes79
Vikes79
SKOL!
10,884
105,591
South Dakota
  2. Talon X4 LV
I have the same in my tractor. They definitely have a place!
I installed an after market heater in the void under the drivers seat.
one tip that I will add is that if you block the factory radiator about 3/4 way, you’ll have all the heat you could want out of the heater.
The Welder
Canada
Hello. What a way to go. There is a gentleman here selling an unused one like yours. I live in northern Alberta (this morning it was -40F out). Does your windshield fog/ice up or did you eventually get a defrost kit? I own a 2019 pioneer 700 deluxe. It has a fabric cab and hard top. I will obviously have to fill in the gaps (pool noodles seem to work). I think I would just plumb into the oil cooler line like the Inferno heaters.
Reactions: Lady01
Scoop
Scoop
4,218
15,779
  3. Talon R LV
Contact Scott @ Coupers Products. They are replacing the MaxStat option with an electric water pump option. It circulates water went the stat is closed and better when at idle.
