P1000 Check your SATV A-ARMS
Rambo
Rambo
339
822
Southern Indiana
Wanted to share what I found twice now on my arched A arms from Super ATV. I found the threaded shaft of the pivot blocks to be a weak point. Both bent in the same spot (at different times), the rear A arm toward the front of the machine. I had both replaced under their lifetime warranty no problem at all!! Also found out they've upgraded the steel used on the A arms. This isn't something that I would have found unless I was readjusting my camber. Those of you with these might want to check. An easy sign to show any damage is to look at the nut on the pivot block and make sure its setting flush agaist the A arm. All super ATV will ask is a pic of the damage and they'll take care of it!!!! Great customer service!!!!!
20171114 191516 20180110 134611
Rambo
Rambo
339
822
Southern Indiana
Are you sure the jam nut was torqued?
I've made a point to check them periodically and never found them backed off. With that said I have found them slightly loose maybe a 1/4 turn.
Super ATV never came out and said this was a know problem but they did say they started using a stronger steal.........
I'm curious to see if I'm the only one who's had this issue.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
No...i believe @Eltobgi had one bend in the same place. Whethe it matters or not i put a drop of blue thread lock on the threads when i tightened mine down.
Rambo
Rambo
339
822
Southern Indiana
I had 3 of my jam nuts come loose in the Overland trip but was able to get them tightened up and the shafts aren’t bent.
Like glock I put thread locker on when I got home and got it cleaned up.
I'll be doing the thread lock now!
Reactions: ToddACimer
pct
pct
Lost in the hills
790
1,023
Letart WV
Thanks for the info I got mine when they first came out I'm getting ready to put a lift and readjust arm settings and will look for it
Reactions: Rambo
Eltobgi
Eltobgi
4,599
15,186
North Dakota
246B76C7 FF14 4697 ADF4 DF693CFA6050 24DD3DED 87FD 4EE8 A798 CA3531AD9E5A 103B11A5 6782 47F6 BBAE 5107574B5188
That is correct! I took photos and was concerned about possible stressed threads in the a arm and they sent me a replacement. Love a company that stands behind their product!
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
Out of curiosity how far was it screwed out? My left is good but my right is still off camber, and I don't want to thread the joint out any farther. I'm wondering if it put stress on it because it was threaded out to far.
208,729
I called and talked to them about this, answer was, 1/4 inch of threads into a arm?????????????
Reactions: dnjones161
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
That's kinda scary since there was slop in the joint with it that far out.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
So far mine haven't given me any trouble. I check jam but periodically and they haven't backed off yet. I'll keep a closer eye on them now.
Rambo
Rambo
339
822
Southern Indiana
I inquired about how many threads were needed before installing, I dont remember the number given but know I had way more than enough.(over a 1/4 inch)You should be fine to adjust camber to a satisfactory point. I've convinced myself that the problem was in the softer steal, now thats been addressed hopefully no more problems. I did make a point to ask Super ATV if there were any limits to warranty claims on the A arms and they said if they break they'll send a new one. (No limit to how many claims) Can't beat that!
Reactions: CumminsPusher
Rambo
Rambo
339
822
Southern Indiana
Went out and measured. I had 5/8" of thread into the arm when it bent.
208,729
If the threaded part is so strong, why didn't they make an adjustment bolt with one end having right hand threads and the other end with left hand threads, machined nut in the middle and two jam nuts with female threads in the a arm and swivel joint. Would be really nice to aline without taking things apart, Like a male turn buckle system. Fronts are not bad to adjust. And then you could get alignment exact.
Reactions: Westtnpioneer
pct
pct
Lost in the hills
790
1,023
Letart WV
Not enough room for one I would guess
500
500
589
932
They sent me 2 zip ties for the rack boots, and one of them is zipped already LOL.
Warranty item???
I may claim it under warranty just for fun and see what they say...
I just received my arms last week. Hopefully they have the higher grade steel threaded pivot blocks.
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
Warranty item???
I thought the same thing. Look closer, it is inserted upside down so it really isn’t zipped
