ehart814
I ripped a boot a couple weeks ago. Got a new Honda OEM boot kit. Had boot replaced and stuffed with grease. I reinstalled the axle and not there is a funny noise when taking off from a stop. It only happens when changing direction - so if I'm going forward and stop and shift to reverse, it will make the noise when I press the gas. Then stop an shift to H or L and press the accelerator it will do it again. It makes the noise when I take the slack out of the drivetrain. I haven't had a chance to lift and and play around.
Is there something I could have messed up when I reinstalled the axle? Or is it most likely the axle itself making the noise? I know I didn't leave anything loose. Just wanted to ask here before going back into it...
