P1000 Clutch relearn question
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
First off, mine are NOT slipping. But it takes a split second longer to get all the way into 3rd gear. It's like the solenoid is delayed for .0001 seconds now. Other shifts are hard and sharp. Think a relearn would benefit me? I don't want to chance ruining how it shifts the other gears so I'm skeptical about trying it. It started this couple weeks ago after fixing my frontend.
Reactions: CumminsPusher
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Sometime I stink at explaining things so let me add this. Before, the solenoid would CLICK getting to 3rd. Now, it's more of a CLIIICK. Once it's in gear, it's in for good. Zero slipping.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Haven't tried it in auto. 99% of the time I keep it in manual mode.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
39,079
Sorry man. I can't help. I haven't done a relearn either
CP: This group looked for anything rough and had a great time. It wasn't all about who was the best or correct line just some good ol boys with a beer and a 4wd.
319,711
Best bet would be oil/filter and a reset. A reset isn't a bad idea imo with some mile laid down. The procedure is a pita and will probably take a couple shots
Reactions: pct and Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Sounds like a plan to me then. I'm kinda cautious about doing it since it does everything else very well. But I guess it might could use it after 1900 miles. Those fibers bound to have some extra clearance between them and steels. A relearn might be the trick.
319,711
The reset itself may not help but I sure don't see it as a negitive. Can't go wrong with new fluid.
L
Luke2404
Memphis Tn
The relearn won’t take, anyone know why? What needs to be done from here?
Mark in Northern Iowa
464
2,074
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from Northern Iowa to @Luke2404
This thread that you posted in is from 2017.
Best thing to do is
1) Introduce yourself to the forum here:
post pics of your ride
2) read all of this thread here:
3) use the search bar and search for others who have had your same problem.
4) if that doesn't help, ask your question by creating a new thread here:
What helps us help you :
Year, make, model
Pics of the dash, showing your problem, a video would be better.
Have a good day
L
Luke2404
Memphis Tn
Best thing to do is
Year, make, model
Have a good day
Thanks buddy, I’m new to this group, I’ll do that! I’ve looked and looked and searched and haven’t found where anyone posted a fix to this problem, I’ll read the posted material though and make an introductory post!
Test - Grid
