P1000 Clutches burnt up
280,983
anything definitive on what changes they are making to the clutches or clutch packs?
So far, there has only been approximately 5 or 6 actual clutches replaced and just as many minor electrical connection / grounding issues causing the problems of those that have been corrected.
Here is the updated list, only 6 or 7 units (from what has been posted and self reported here) still waiting to have issues resolved:
P1K Issues 3 20 16
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
I talked to my dealer yesterday and let him know the issue I was having. They are going to call the Honda service rep and get him to come out. I was told to enjoy it until they can get a time when he can be there.
The service manager called me today and let me know that he had gone into this forum and saw that others were having issues. He already ordered both clutch packs so we don't have to wait once Honda gives the go ahead. If it isn't the clutch, I'm sure they will use the clutch packs at some point.
Reactions: pct
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
That's how a dealer should be! It's a wear item so its not like they'd sit on the shelf forever anyways.
ghost
ghost
993
1,874
BC
Jackal did the hard work compiling the list but here are the stats as of today (18 users reported a problem)
823 replies to thread / 18 reported problems = 45.7 replies / problem
47,321 views / 18 reported problems = 2629 views / problem
Whatever... I did the math so thought I would share it.
P1k5d_rg
P1k5d_rg
9
West, Tx
I'm new here but have the same problem with my 1k deluxe.. it started around 500 miles and I have around 600 on it now. I plan on checking the ground wires later tonight. Is there any other "quick fix" my dealer test drove the machine and seems to think it's oil pressure related..
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
What issue do you have the 1,3,5 and reverse slipping? Or it not wanting to move until you get above 3,000 rpms.?
P1k5d_rg
P1k5d_rg
9
West, Tx
1,3,5. If I put it in sport mode 3rd gear isn't that noticeable but 5th gear will throw you around in the seat. I changed the oil 10 miles ago. Now I'm going thru the ground wires and unhooking the extras.
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Ok report back.
A
aquatic1998
94
46
Didn't fix it.. to save the next guy some skin on his fingers, is there an easy way to get to the green ground and black small motor ground under the drivers seat between the plastic?
No not really I took the floor plastics out and was able to get to them fairly easy. Took alittle time but not bad .
Reactions: pct
Buckrocker
Buckrocker
99
124
Rock, WV
19 reported now
dale5740
dale5740
886
417
mt airy md
My dealership pulled clutch packs all burnt up I ask for a new ride or a extended warranty incase it happens again got to talk to Honda I said I want something in writing so I know I will be covered. Also I want something for my troubles waiting on them to see what happens
did u grill them to find out what the exact reason was that caused them to burn up?????
Reactions: pct
Hawk53
Hawk53
485
625
Alberta Canada
Wonder if there is any relationship to build dates and failures ?
Reactions: pct
dale5740
dale5740
886
417
mt airy md
If I'm having no problems at all should I still be going and checking the ground wires an all that or let it present itself lol?
Reactions: pct
280,983
Does not appear to be any correlation to build date or VIN, but most issues reported were done so within the first 200 miles, or right after the initial oil change. Seemingly random in who it affects even with how the machines are used.
Reactions: pct
