This is how it happen I was in 4 wheel lock low gear. Tring to climb out a sandy hard bottom hole. Front tires where on top of natural ground. With gas petel all the way it would barly I mean barly turn the tires. Only let it try to pull like that that for prob 10-15 seconds seen it wouldn't pull backed off. I would not suggest putting a strap on anyone to pull them out this would duplicate my senerio. Just to clearify I wouldn't say clutch it burnt in 1,3,5 it just slips on initial engagement for about 2 seconds once it engages it's solid. Basically if you have the gas petal pressed tires better be turning or you going be in same boat !
