Yes Sir, I have 3 of them. By the CO2 tank from your local welding shop and then the regulator off Amazon. I'll see if I can find the last one and post a link.
High Flow 150 PSI Fixed Flow Carbon Dioxide Piston Regulator for Tire Inflation - - Amazon.com
www.amazon.com
I have a 20Lb cylinder on my trailer for the truck, trailer and/or the buggy before I leave out. I have aired up over 30 truck tires with it before having it refilled.
I carry a 5Lb in the buggy and a 25ft hose. Absolutely will not leave home without it.
Even have the little cylinders on my 4 wheeler and use the bicycle kit you get at Walmart, just takes about 4 to 6 to fill a tire. Just make sure you buy the ones with the threads on them and not the smooth ones.
Amazon.com : PRO BIKE TOOL CO2 Inflator + 5 x 16g Threaded CO2 Cartridges Bundle - Quick & Easy - Presta and Schrader Valve Compatible - Bicycle Tire Pump for Road and Mountain Bikes : Sports & Outdoors
www.amazon.com
